2012 TL to have a better 0-60?
Old 02-10-2011, 11:50 PM
jharrison's Avatar
my main issue with the 2009+ TL was the lack of acceleration compared to my 2007 S-type. I can't bring myself to buy an updated version of a car that is actually slower. I know the manual transmission version is faster than my type s auto (5.2 vs. 5.7) but i wasn't looking for a manual. some have speculated that the 2012 6 speed auto will be faster than the 5 speed 2011. does anyone know this will be the case? if not, it's tempting to look at the g37 (5.1).
Old 02-11-2011, 12:05 AM
2010_TL's Avatar
The new 6 speed auto should have better acceleration than the '09-'11 5 speed auto due to the better gearing. It'll probably have about the same numbers as the 6 speed manual transmission.
If you wanna compare the acceleration between the '07-'08 Type S and the '09+ TL SH-AWD, they're actually pretty similar. I've done a couple runs against my buddy's 2007 Type S(both auto) from zero to about 60-70mph and it was always either dead even or I was about a half car in front.
Old 02-11-2011, 12:11 AM
jharrison's Avatar
good to know
i'm just going off the numbers i see in car mags...seems pretty consistently reported that the 4g sh-awd is a little slower than the type s but i believe you. i was actually thinking of goingto the dealership and asking them if they would race a 4g against my type s and if they won i'd buy the car (i would have decided to buy the car ahead of time)
Old 02-11-2011, 12:25 AM
2010_TL's Avatar
Lol I dont think that will work but its worth a try
Old 02-11-2011, 12:41 AM
Ken1997TL's Avatar
Received 2,329 Likes on 1,309 Posts
Speed in a FWD six cylinder car is this important to you?
Old 02-11-2011, 06:36 AM
YetiTL's Avatar
Well, I'll extend an arm here and do a guess: if I consider the improvement made to the RL and MDX with the 6AT vs 5AT, I expect a solid 0.5 sec gain in 0-60 and 1/4 mile. More might be possible but not more than 0.7 which will put the 2012 TL SH-AWD in the 5.3-5.5 sec range. If you consider that the lack of launch ability (versus a clutch drop or something), it will be quite similar to the 6MT.
, YMMV
Old 02-11-2011, 08:36 AM
Pete2010's Avatar
I would also bet that the gearing matches the 6MT closely, maybe more centered on fuel economy, but would expect to see sub 6-sec 0-60 closer to the 6MT. But I agree with Ken, if you're looking for a 0-60 car, a two ton sport sedan should not be on your list. A few tenths of a second probably won't even be noticeable to the "butt dyno".
Old 02-11-2011, 10:11 AM
Mr Marco's Avatar
Anything around 6sec should be acceptable. It akin to the difference (.1sec) between the A4 Quattro vs A4 FWD.
Old 02-11-2011, 10:34 AM
jjsC5's Avatar
, YMMV
Don't forget that the MDX and RL in addition to the six speed also got a fairly heavily revised 3.7 engine that reportedly had a broader torque spread.
Old 02-11-2011, 12:20 PM
KevTL-S's Avatar
You gotta be kidding me. All of the numbers I have seen are closer to 7.
Old 02-11-2011, 01:37 PM
Mr Marco's Avatar
Need someone with a GTech-Pro SS to give us a real 0-60.
Anyone done this???
Old 02-11-2011, 01:57 PM
winstrolvtec's Avatar
Numbers in general are all over the place. You could find at least a .5 sec difference depending on who's testing and all the other variables involved on almost any car. The TL SH auto for example, has shown a range 0f 0-60 from 5.9-6.5 and 1/4 high of 14.3 to a low of 15.1.
I think 5.7 for an auto TLS, although possible, is a bit much, the cars seems to hang around the 6 sec range, give or take one. That's in line with the better numbers from the 5AT SH.
To the OP, I can't imagine the 6AT FWD TL for 2012 will be any slower than the previous 5AT TLS. IMO, the worst case is it will be the same and you can enjoy the extra gas mileage. If you want a little more, I would guess that Acura would want the SH to remain the sportier variant and maybe re-emphasize that this time around as the current models are fairly similar in that regard, so the 6AT SH should retain it's shorter final drive (maybe even more agreesive than now) and obviously the added traction compared to the FWD but we'll see soon enough.
Old 02-11-2011, 02:04 PM
saturno_v's Avatar
Why, FWD cars have no "right" to be fast???
Old 02-11-2011, 02:42 PM
YetiTL's Avatar
I think it has more to do with torque steer than anything else...
Old 02-11-2011, 02:44 PM
YetiTL's Avatar
Well, we can try to have our cake and eat it too I guess, no?
Seriously I saw a vid of a CTS-V drag strip monster: quater mile in 9.85 sec, that's pretty retarded for a 4300 lbs 6AT sedan.
Personally, I think the SH-AWD TL does a good impersonation of a pratical sport car and we can use it all year around...
Old 02-11-2011, 02:51 PM
YetiTL's Avatar
2009 TL SH-AWD 5AT
R&T 5.9/ 14.4
C&D 6.0/ 14.7
And yes, we'll see soon enough with some test results.
Old 02-11-2011, 02:55 PM
jasonwdp10's Avatar
I speak from experience when I say that from a stop, my Base model loses all it's steam due to the wheels slipping (esp when it's raining). Either the wheels slip or I need to ease in on the throttle which makes it impossible to acclerate quickly from a stop. My SHAWD did not have this problem rain or shine.
Old 02-11-2011, 02:56 PM
Received 16,266 Likes on 11,974 Posts
sounds like a tire issue.
Old 02-11-2011, 03:05 PM
saturno_v's Avatar
I drove the 4G TL FWD and I saw very little torque steering......it is safe to say that if the car is properly designed, a FWD platform (about the size of the TL and its competitors) can digest up to 300 horses with no problem.
I test drove the new Maxima and it was almost flawless too.
Now if we talk about 545 or M5 ballpark, that is a different story.
But like you said, the TL is a practical sport sedan...
Old 02-11-2011, 05:02 PM
I'm Craig
cjTL's Avatar
7 sec 0-60 in a 3G TL would be the worse-case scenario. For the 3G TL, little over 6 seconds for 5AT, and Car & Driver did 5.7 in the 6MT "back in the day".
Old 02-11-2011, 10:35 PM
KevTL-S's Avatar
For a 6MT, the 5's are a little optimistic, but believable. The OP, however, said a low to mid 5 for an auto, which is totally unrealistic.
Here's MotorTrend's result of 6.5
http://www.motortrend.com/roadtests/...ict/index.html
Don't believe in numbers on paper? Well, my 5.5 GS spanked a 3rd Gen a month back, and this is after he shot out of the hole while the light was still red. No matter, I reeled him in, and wave bye-bye as I went by. Afterwards, I wanted to comment on his behavior, but he wouldn't roll his window down, and eventually made a u-turn. So, if a 3rd Gen is a 5's vehicle then it would have put up a much better showing against a 5.5 GS.
Old 02-11-2011, 10:57 PM
saturno_v's Avatar
The manual TL SH-AWD did the 0-60 in 5,2 and the quarter of mile in 13,7 tested by C&D
Old 02-12-2011, 07:02 AM
JM2010 SH-AWD's Avatar
R&T's times for the 6MT TL (2010) are identical to C&D's. It's a 5.2 car 0-60. Plenty quick.
Old 02-12-2011, 08:41 AM
The Sicilian
jspagna1's Avatar
+1 I'm with you on this one. If it's a daily driver, I want comfort, class and speed in that order.
Old 02-12-2011, 01:14 PM
I think the 6AT FWD will be limited to just breaking 5's to low 6's just due to the nature of the front drive layout, while the SH with a 6AT should consistently get into the mid to high 5 territory.
I don't think that's unrealistic based on what we have already seen and given the addition of another gear and what that has done to other Acura models but we will need to see a few test results to be sure.
Old 02-12-2011, 01:51 PM
Ken1997TL's Avatar
I never said that. But it seems speed is very important to the OP, so much that he was willing to buy a new car if it beat his current one.
Old 02-12-2011, 02:27 PM
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
2009 TL SH-AWD 5AT
R&T 5.9/ 14.4
C&D 6.0/ 14.7
I believe that's in line with a 3G TL-S auto. I did mine 14.37 @ 97 mph; Avg of 7 runs = 14.49 @ 96 mph.
That was a Type-S right 6MT right? Not Base 6 MT.
Edit: ehh. Maybe not. I was thinking of this one: http://www.roadandtrack.com/var/ezfl...b477099096.pdf
Impressive.
Old 02-12-2011, 07:56 PM
The Sicilian
jspagna1's Avatar
Originally Posted by Bearcat94
I believe that's in line with a 3G TL-S auto. I did mine 14.37 @ 97 mph; Avg of 7 runs = 14.49 @ 96 mph.Impressive.
Hey a 14 second car on the street is fast. A 12 second car on the street is sick! Can you tell I'm talking Drag Racing terminology?
Old 02-13-2011, 12:28 AM
I think that was a base 6MT A-spec, not that the A-spec really made that much of difference than just a high performance tire model, which is what most of the times are usually based on anyway.
I have seen plenty of sub six seconds runs and low 14's, especially 14.2's, from just regular 3G base 6MT models.
http://www.motortrend.com/roadtests/...fications.html
Old 02-13-2011, 11:24 AM
AZ Community Team
Bearcat94's Avatar
Right. I remember seeing that on too.
Which kind of gets tothe problem of "what is the 0 - 60 time?". They're all over the place.
A 2004 base MT does 5.7 AND a 2007 TL-S MT does 5.7? I just don't believe they're the same. I would expect a few tenths differential. Sometimes there is, sometimes there isn't.
Doesn't matter what year, what generation, what powertrain: numbers are all over the place and the best you can do is say 0 - 60 is about x.xx.
Old 02-13-2011, 08:27 PM
Moneyman2011
Guest
Posts: n/a
A very close friend of mine just confirmed the following performance stats:
  • 0-60 5.45 with VSA engaged
  • 0-60 5.59 with VSA off
  • 1/4 mile 13.91 @ 103.4 mph
Old 02-13-2011, 09:55 PM
deeblew's Avatar
Where are these numbers from? I'm assuming they are for the AT? Any idea what the MT will be?
Old 02-13-2011, 10:05 PM
Moneyman2011
Guest
Posts: n/a
Yes it applies for AT. I am told that HP numbers are not changed, but the TQ curve is broader than in the 2009-2011 3.7 engines because of friction reducing and air intake improvements. Also MPG is 20/28. The gear ratios are almost identical to the Manual, so the performance between AT & Manual will be almost the same. A first for Acura!
Old 02-13-2011, 10:33 PM
Pete2010's Avatar
^^ Any more info other than "close friend"?
Old 02-13-2011, 10:38 PM
ostrich's Avatar
Moneyman2011, you posted this in the other thread:
"Yes it applies for AT. I am told that HP numbers are not changed, but the TQ curve is broader than in the 2009-2011 3.7 engines because of friction reducing and air intake improvements. Also MPG is 20/28. The gear ratios are almost identical to the Manual, so the performance between AT & Manual will be almost the same. A first for Acura!"
Oh my goodness! The performance improvements are amazing! It's now about as fast as the G sedan, and the fuel economy is class-leading, right?!
I WANT A 2012!!!!!!!!!!!!!!!!!!!!!!!!!!! LOL
Old 02-13-2011, 10:41 PM
silver01cltypes's Avatar
yes more info on the perfromance stats.sure thats the 6at or manual?is it fwd or shawd?
Old 02-13-2011, 10:45 PM
deeblew's Avatar
His stats are for the 6AT SH-awd.
Old 02-14-2011, 07:06 AM
Moneyman2011
Guest
Posts: n/a
My friend is very close to the development team and as a promise to him, I will not disclose who it is, but you can be sure this information is material and credible. I can tell you that he said that performance numbers improve as the car breaks in after about 2500 miles. He said that although the service manual does not say that synthetic oil is required, the new engine modifications responded greatly to Valvoline or Mobile One lubricants. Another thing he said is that the changes are able to be felt in the seat of the pants if you drive a 2011 back to back with a 2012. The new 6 speed will kick down from 6th to 2nd or 5th to 2nd any gear into 1st if below 30mph in WOT. It blips the revs prior to engaging the gear as it in 2009 and later models. The 6 speed is the same in both SH-AWD and standard models. He said that standard models saw improvements in performance on par with 2011 to 2012 SH-AWD models. Lastly he said that the reduction in interior noise is very noticeable for all models.
Old 02-14-2011, 09:15 AM
I have car ADD
BLACKURA_NY's Avatar
your "friend" seems very smart and i enjoy his insight
Old 02-14-2011, 09:38 AM
The Sicilian
jspagna1's Avatar
Those are real good times for a car that heavy.
Quick Reply: 2012 TL to have a better 0-60?
