2012 Acura TL Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2012 Acura TL Technical Service Bulletins:
TSB 11-005 - 2012 TL: TQI Information
Applies To: 2012 TL - All
http://www.urvi.net/forumfiles/SB/B11-005.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-005.PDF
TSB 08-041 - 2009-13 TL: TQI of the Navigation System
Applies To: 2009-13 TL With Navigation - All
http://www.urvi.net/forumfiles/SB/B08-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B08-041.PDF
TSB 09-059 - Front Door Panel Fabric Pulls Out Along the Edge
Applies To: 2009-12 TL - All
http://www.urvi.net/forumfiles/SB/B09-059.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B09-059.PDF
TSB 10-008 - Retractable Master Key Does Not Lock in Its Extended Position
Applies To: 2009-12 TL (without push button start)
http://www.urvi.net/forumfiles/SB/B10-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.PDF
TSB 11-004 - Clutch Pedal Pops, Squeaks, or Clicks
Applies To: 2010-11 TL - All with M/T
2012 TL with M/T - From VIN 19UUA9E..CA000001 thru 19UUA9E..CA000672
http://www.urvi.net/forumfiles/SB/B11-004.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-004.PDF
TSB 11-012 - TIGHTEN FUEL CAP Message Is On Without DTC P0455 or P0456
Applies To: 2012 TL 2WD – From VIN 19UUA8...CA000001 thru 19UUA8...CA005403
2012 TL SH-AWD A/T – From VIN 19UUA9F..CA000001 thru 19UUA9F..CA011151
2012 TL SH-AWD M/T – From VIN 19UUA9E..CA000001 thru 19UUA9E..CA011466
http://www.urvi.net/forumfiles/SB/B11-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B11-012.PDF
TSB 11-016 - HFL Phonebook Imports Each Time, Call History Refreshes Each Time, Voice Tag Doesn’t Work, and AcuraLink Voice Unclear
Applies To: 2012 TL with Navi - From VIN 19UUA8...CA000001 thru 19UUA8...CA009401 and From VIN 19UUA9...CA000001 thru 19UUA9...CA002936
http://www.urvi.net/forumfiles/SB/B11-016.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-016.PDF
TSB 11-024 - Rear Shelf Area Clicks, Taps, or Ticks
http://www.urvi.net/forumfiles/SB/B11-024.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-024.PDF
TSB 11-025 - Right Rear Wheelwell Area Clicks, Taps, or Ticks
http://www.urvi.net/forumfiles/SB/B11-025.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-025.PDF
TSB 11-027 - Upper B-Pillar or Moonroof Area Clicks, Rattles, or Taps
Applies To: 2009–11 TL – All
2012 TL 2WD – From 19UUA8...CA000001 thru 19UUA8...CA030468
2012 TL SH-AWD – From 19UUA9...CA000001 thru 19UUA9...CA009652
http://www.urvi.net/forumfiles/SB/B11-027.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-027.PDF
TSB 12-013 - MID Shows BATTERY CHARGE LOW
Applies To: 2012 TL 2WD - From VIN 19UUA8...CA000001 thru 19UUA8...CA008239
2012 TL SH-AWD - From VIN 19UUA9...CA000001 thru 19UUA9...CA002516
http://www.urvi.net/forumfiles/SB/B12-013.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-013.PDF
TSB 12-041 - Front Suspension Clunk in Hot Weather
Applies To: 2009-13 TL - All
http://www.urvi.net/forumfiles/SB/B12-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-041.PDF
TSB 13-007 - Rattle or Vibration From the Rear Speakers
http://www.urvi.net/forumfiles/SB/B13-007.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-007.PDF
TSB 14-006 - MIL Comes On With DTC P0455 and/or P0456
Applies To: 2012 TL - All - All
2013 TL - 2WD - From VIN 19UUA8...DA000001 - 19UUA8...DA000686
2013 TL - SH-AWD - From VIN 19UUA9...DA000001 - 19UUA9...DA000191
http://www.urvi.net/forumfiles/SB/B14-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-006.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2009-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2006-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up
Applies To: 2012-14 TL - ALL with A/T - ALL
http://www.urvi.net/forumfiles/SB/B14-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-049.PDF
TSB 15-013 - Driver’s Seat Cushion Cover Comes Loose
Applies To: 2012-14 TL - Advance, Advance with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B15-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-013.PDF
TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator
Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF
TSB 16-030 - Product Update: 2012 TL Software Update for Lock-up Clutch Function
Applies To: 2012 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-030.PDF
TSB 16-040 - Warranty Extension: 2012 TL Torque Converter
http://www.urvi.net/forumfiles/SB/B16-040.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-040.PDF
TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch
This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-046.PDF
TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations
The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B18-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2012 TL - 2WD - From VIN 19UUA8F...CA035307 thru 19UUA8F...CA040693
2012 TL - 4WD - From VIN 19UUA9F...CA011186 thru 19UUA9F...CA012783
2013-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-047.PDF
TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B18-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-048.PDF
TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-021 - Warranty Extension: Steering Feels Heavy, EPS Indicator Blinks with No DTCs or Comes On Steady with DTC 32-09, 32-08, or 61-04
Applies To: 2012-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-021.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B19-021.PDF
TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator
http://www.urvi.net/forumfiles/SB/B19-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF
TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B19-052.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 1999-14 TL
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030)
http://www.urvi.net/forumfiles/SB/B20-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF
The following 8 users liked this post by EE4Life:
bigwavedave25 (03-09-2020),
Blaze9 (05-31-2018),
didier9 (11-26-2018),
dregsfan (03-16-2018),
Mak P (12-08-2017),
and 3 others liked this post.
TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch was revised. This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Added new TSBs:
TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required).
TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required).
Added new TSBs:
Interesting observation in looking at the TSB's details. There's a list of parts required if they need to do the tear-down work. In that list, they indicate as an oil filter 15400-PLM-A01 . Seems very interesting to me they specifiy the Filtech version of the filter, rather than the -A02 version that has been the default choice for the last decade or so....... Hmm.....
Generally if holding a steady throttle while going up a slight hill you'll feel a judder, and see the rpms jumping up and down just a hundred or so rpms. Flushing the ATF and updating the software has fixed like 98% of the issues that I've seen.
ok so is this in addition to the previous recall for the airbags last year? Or just a reminder TSB from the orhginal TAKATA issue. because on the Acura site when I put in the VIN for my 2012 TL (which is listed in the new TSB) it says no recall repair required.
death (09-13-2019)
Forum Contributor
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
