2011 Acura TL Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2011 Acura TL Technical Service Bulletins:
TSB 10-029 - 2011 TL: TQI and New Model Service Information
Applies To: 2011 TL - All
http://www.urvi.net/forumfiles/SB/B10-029.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B10-029.PDF
TSB 08-041 - 2009-13 TL: TQI of the Navigation System
Applies To: 2009-13 TL With Navigation - All
http://www.urvi.net/forumfiles/SB/B08-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B08-041.PDF
TSB 09-012 - MID or Navi Shows a Check Engine Oil Level Message, Low Oil Pressure Indicator May Be On
Applies To: 2009-11 TL - All
http://www.urvi.net/forumfiles/SB/B09-012.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B09-012.PDF
TSB 09-059 - Front Door Panel Fabric Pulls Out Along the Edge
Applies To: 2009-12 TL - All
http://www.urvi.net/forumfiles/SB/B09-059.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B09-059.PDF
TSB 10-008 - Retractable Master Key Does Not Lock in Its Extended Position
Applies To: 2009-12 TL (without push button start)
http://www.urvi.net/forumfiles/SB/B10-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B10-008.PDF
TSB 11-004 - Clutch Pedal Pops, Squeaks, or Clicks
Applies To: 2010-11 TL - All with M/T
2012 TL with M/T - From VIN 19UUA9E..CA000001 thru 19UUA9E..CA000672
http://www.urvi.net/forumfiles/SB/B11-004.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-004.PDF
TSB 11-024 - Rear Shelf Area Clicks, Taps, or Ticks
http://www.urvi.net/forumfiles/SB/B11-024.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-024.PDF
TSB 11-025 - Right Rear Wheelwell Area Clicks, Taps, or Ticks
http://www.urvi.net/forumfiles/SB/B11-025.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-025.PDF
TSB 11-027 - Upper B-Pillar or Moonroof Area Clicks, Rattles, or Taps
Applies To: 2009–11 TL – All
2012 TL 2WD – From 19UUA8...CA000001 thru 19UUA8...CA030468
2012 TL SH-AWD – From 19UUA9...CA000001 thru 19UUA9...CA009652
http://www.urvi.net/forumfiles/SB/B11-027.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B11-027.PDF
TSB 12-029 - Warranty Extension: Torque Converter, Product Update: PCM Update for Lock-Up Clutch Function
Applies To: 2009-11 TL with SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B12-029.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-029.PDF
TSB 12-041 - Front Suspension Clunk in Hot Weather
Applies To: 2009-13 TL - All
http://www.urvi.net/forumfiles/SB/B12-041.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-041.PDF
TSB 13-007 - Rattle or Vibration From the Rear Speakers
http://www.urvi.net/forumfiles/SB/B13-007.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-007.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2009-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2006-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator
Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF
TSB 16-033 - Warranty Extension: Software Update for Lock-up Clutch Function Based on Client Complaint
Applies To: 2009-11 TL - ALL 2WD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-033.PDF
TSB 16-036 - Warranty Extension: 2009–11 TL Torque Converter
http://www.urvi.net/forumfiles/SB/B16-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-036.PDF
TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations
The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B18-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator
http://www.urvi.net/forumfiles/SB/B19-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF
TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B19-052.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 1999-14 TL
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030)
http://www.urvi.net/forumfiles/SB/B20-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF
I have this exact problem, but am out of warranty. Is their any recourse for this or is this completely an out-of-pocket expense to get this fixed?
Forum Contributor
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
