2010 Acura tl sh-awd custom headlights and taillights
Old 04-24-2020, 10:18 PM
9th Gear
4genshawd's Avatar
Hey everyone just looking for a little insight on which direction to take in regards to either painting my headlight housing black or tint or buying custom. I have looked everywhere for black headlights online for 2010 and it seems like there are none to be found. Also looking to either tint my taillights a shade of black or just the white reflector part... Thoughts?
Old 04-25-2020, 11:04 AM
jutes85's Avatar
It's very easy to do. Remove the three phillips screws on the back of the headlight securing the lens to the frame. Set your oven to 280F and bake each headlight for 7-8 minutes, that's enough to soften the glue. Pull the lens apart and wala, you can paint anything you want to your hearts desire. Don't bother wasting your money with blacked out headlights, this entire project will cost under $20 and look 100% better.
Old 04-25-2020, 12:26 PM
9th Gear
4genshawd's Avatar
My only worry is not being able to seal the headlights back up properly
Old 04-25-2020, 01:24 PM
jutes85's Avatar
You could always buy some butyl tape like this:
Amazon Amazon
and add a strip along the edges. I've used Nissan OEM Butyl tape in my retrofits and never had an issue with condensation. On the back of the TL headlights there are rubber caps you can remove to let any moisture out.
Tony Pac
03-06-2020 08:19 AM
qnzjay69
08-01-2014 11:55 PM
Quick Reply: 2010 Acura tl sh-awd custom headlights and taillights
