2009 TL initial Start up noise
Hello, on cold starts I get a strange start up noise. It sounds like a high pitch Hunnnn... and then everything seems normal. I was thinking maybe its the start of the timing belt. 61000 miles. Adv with tech.
If it happens right when you turn the key and lasts about 3-4 seconds, it's the starter. Mine had the same issue and got it fixed under the extended warranty (receipt showed $478 parts + labor).
However, now after a cold start my base TL has started to screech AFTER initial startup for about 15-20 seconds. I guess I gotta take it to the dealer again, lol.
I just purchased the car 3 weeks ago and noticed the sound every time I started the car when it was below 30 degrees. At first I thought this was normal when the car is cold but after reading this forum I took it to the dealer right away and they diagnosed that it required a new starter engine.
