2009 Acura TL trouble code
My 2009 TL was sitting in the garage for an extended period due to harsh winter. When i went to start it, battery would barely turn over. Put battery charger on car for a few hours and car started and ran fine.
Problem is that a few days later my check emission system light came on, NAV codes state P0305, P0306, P0304, P0300. Engine may not operate properly, acceleration may be reduced.
I am not sure if battery has anything to do with this or not.
Any ideas on the code ?
misfire codes p0305 is cyl 5 p0306 is cyl 6 304 is cyl 4 and p0300 is random misfire code no specific cylinder.You sure it ran ok after it sat and started?You can have the codes cleared with a scanner or just pull a battery cable for a few mins and see if it recodes again.Are you still under warr?Have a dealer check it out let them clear it so if it recodes its on file.Maybe they have a bulletin on this?
could also be winter fuel mix.... if you live in the northern part of the country, they put additives in the fuel for the winter
my Type-S (UA7) would ALWAYS throw emissions codes in the winter, if i let her idle too long. i never had a problem with my 4G though
mada51589
05-03-2022 09:54 PM
handsom-hustla
11-13-2015 06:04 PM
elietania
4G TL Problems & Fixes
09-05-2015 07:52 AM
