Custom iPhone Wireless Charger
Some of you may have seen my previous post about swapping out the non-function iPhone wireless charger. Well I took it a step further and custom designed and 3D printer one to use with the Apple MagSafe charger.
If there is enough interested I may end up selling them.
Hi Brandon. Awesome work! I’ve been working on something similar for my Integra. I was hoping that the MDX and Integra shared the same OEM pad, but they are very different in length. I verified this since my wife has an MDX.
I have taken apart my center console in order to get a better idea as to what options I have. I have an iPhone, and the goal was always to use a MagSafe puck along with some sort of hidden-away power source of +20W. I wanted the whole thing to be as OEM looking as possible with no visible wires.
At first, I wanted to create a 3D printed tray. Then I came across your two posts. I ordered a MagSafe charger to test out if I could simply attach it from the bottom of the pad, but I ran into a problem. I have an iPhone 15 Pro Max, and the camera bump prevents the phone from laying flat on the tray. If I move the phone over the edge so that it lays flat, the charging works. That’s why your creation with the Acura logo “bump” is the perfect workaround.
I don’t have experience with CAD software, but I’m pretty tech savvy. Can I scan my charger top case, or do I need to take every measurement and enter it manually? I also don’t have a 3D printer, but I am in the process of checking with my local library.
Any suggestion/advice? Also, how thin did you have to make the logo for it to have a good connection?
If you were to sell the MDX piece, how much shipped to 33177?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
pavementprincess (02-07-2024)
Thanks!!
Thanks!!
I’ve never 3D printed anything but I think you can upload your design to thingiverse and then others can leverage your skillful design to print themselves. Really love seeing the ingenuity. This type of solution would seem to solve MagSafe charging issues for iPhone users across many car models
Zelaya
10-14-2014 10:53 AM
PATR1NYC
02-07-2012 02:38 PM
