2023 Acura MDX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2023 Acura MDX Technical Service Bulletins:
TSB 22-011 - 2023 MDX: TQI Information
Applies To: 2023 MDX - 2WD - Base, With Technology Package
2023 MDX - SH-AWD - Base, With A-Spec Package, With Technology Package, With Advance Package
http://www.urvi.net/forumfiles/SB/B22-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-011.PDF
TSB 22-012 - 2023 MDX: TQI of the Navigation System
Applies To: 2023 MDX - ALL with Navigation
http://www.urvi.net/forumfiles/SB/B22-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-012.PDF
TSB 22-013 - 2023 MDX Type S: TQI Information
Applies To: 2023 MDX - Type S SH-AWD
2023 MDX - Type S Advance SH-AWD
http://www.urvi.net/forumfiles/SB/B22-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-013.PDF
TSB 23-001 - Product Update: 2016-23 MDX PGM-FI Idle Stop Software Update
Applies To: 2016-20 MDX - All (except Hybrid) - Check the iN VIN status for eligibility
2022-23 MDX - All (except Hybrid & Type S) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B23-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-001.PDF
TSB 23-004 - Panoramic Glass Roof has a Pop Noise
Applies To: 2022-23 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-004.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2022-23 MDX - ALL (except Type S) - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-011 - After Idle Stop Engages, Vehicle Does Not Auto Restart
Applies To: 2022 MDX - ALL (Except Type S) - ALL
2023 MDX - ALL with 2WD - From VIN 5J8YD9...PL000001 thru 5J8YD9...PL004277
2023 MDX - ALL with SH-AWD - From VIN 5J8YE1...PL000001 thru 5J8YE1...PL020064
http://www.urvi.net/forumfiles/SB/B23-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-011.PDF
TSB 23-013 - RDX/MDX Sunroof and Sunshade Function Loss
http://www.urvi.net/forumfiles/SB/B23-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-013.PDF
TSB 23-019 - Clunking or Looseness in the Outer Tie Rod
Applies To: 2022 MDX - TYPE S (TECH) - From VIN 5J8YD8H...L000015 thru 5J8YD8H...L005545
2022 MDX - TYPE S (ADVANCE) - From VIN 5J8YD8H...L000037 thru 5J8YD8H...L005665
2023 MDX - TYPE S (TECH) - From VIN 5J8YD8H...L000065 thru 5J8YD8H...L000719
2023 MDX - TYPE S (ADVANCE) - From VIN 5J8YD8H...L000008 thru 5J8YD8H...L002851
2022 MDX - TECH - From VIN 5J8YD9H...L000001 thru 5J8YD9H...L012341
2023 MDX - TECH - From VIN 5J8YD9H...L000007 thru 5J8YD9H...L005216
2022 MDX - BASE - From VIN 5J8YD9H...L000266 thru 5J8YD9H...L011256
2023 MDX - BASE - From VIN 5J8YD9H...L000181 thru 5J8YD9H...L005259
2022 MDX - ADVANCE - From VIN 5J8YE1H...L000001 thru 5J8YE1H...L052372
2023 MDX - ADVANCE - From VIN 5J8YE1H...L000014 thru 5J8YE1H...L025731
2022 MDX - A-SPEC - From VIN 5J8YE1H...L000263 thru 5J8YE1H...L052452
2023 MDX - A-SPEC - From VIN 5J8YE1H...L000136 thru 5J8YE1H...L026114
2022 MDX - BASE - From VIN 5J8YE1H...L000791 thru 5J8YE1H...L044295
2023 MDX - BASE - From VIN 5J8YE1H...L000244 thru 5J8YE1H...L026222
2022 MDX - TECH - From VIN 5J8YE1H...L000623 thru 5J8YE1H...L052342
2023 MDX - TECH - From VIN 5J8YE1H...L000124 thru 5J8YE1H...L026293
http://www.urvi.net/forumfiles/SB/B23-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-019.PDF
TSB 23-033 - 2022–24 MDX Popping/Crackling from the Speakers; Display Blank
This bulletin has been replaced by 24-047 Warranty Extension: 2022–24 MDX Popping/Crackling from the Speakers; Display Blank, dated July 30, 2024. This service bulletin will expire August 29, 2024.
http://www.urvi.net/forumfiles/SB/B23-033.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-033.PDF
TSB 24-025 - Rear Wheel Area Screeching or Scraping
Applies To: 2022-25 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B24-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-025.PDF
TSB 24-047 - Warranty Extension: 2022–24 MDX Popping/Crackling from the Speakers; Display Blank
Applies To: 2022-24 MDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B24-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-047.PDF
r10apple (10-12-2023)
