2022 rear turn signal not working. Fast blink on front and side mirror
Pop off the cover and use a multimeter to test the bulb for voltage while having the rear turn signal on. If you're not getting voltage, then there is a break in the wiring somewhere. Could be in the liftgate wiring molding.
wtf, the mdx still doesn’t get led turn signals?
Ah ok, in that case, the fast flash probably isn't due to one of the lights going out. LEDs have such low voltage draws that even if one were to "burn out", that delta wouldn't be enough to trip a relay into fast flash mode
drkangel348
06-27-2005 02:42 AM
