Xxr 530
#43
#44
^ I was actually leaning more toward the matt but only because i saw dougboy and this thread
https://acurazine.com/forums/showthr...&highlight=DMM
I bet the chromium would look good too
#46
hmmmmmm...oh wait... nvm.
is this the right fitment for 06 tl just being on the safe side...
Wheel Size
18x8.75
Color
Chromium Black
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
5.66
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
21.2
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
Wheel Size
18x8.75
Color
Chromium Black
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
5.66
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
21.2
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
#53
that's correct...that is what joe from nlmotoring told me ill get it in mid March.
#54
I like the style of the 530s and can't wait to see them installed. But I hope your credit cards weren't charged more than a good-faith deposit...kinda defeats the purpose of a pre-ordering discount if you put it on a cc and then carried the interest for an extra three months on wheels you're not using.
#55
nice but isnt there other wheels very similar in look and price range that can be had sooner than March? The concave mesh style seems popular with different manufacturers just curious?
#56
#58
Wheel Size
18x8.75
Color
Chromium Black
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
5.66
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
21.2
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
Wheel Size
18x8.75
Color
Chromium Black
Bolt Pattern
5-100/5-114.3
Offset
+20
Backspacing
5.66
Centerbore
73.1
TPMS Compatible
Yes
Approx. Weight
21.2
JWL/VIA Certified
Yes
Required Lug Nuts
Tuner Style
#59
I just saw this thread randomly as I have been planning to buy some new wheels.
I am not familiar with wheel fitmets at all. I am currently at stock height with my 08 type s. I plan to get the H&R sport springs for a slightly lower look this summer.
I do not want to worry about rubbing/rolling/stretching/pulling or any other fitment work.
Please help me to get the wheel and tire specs that will give the best look.
on another note are these wheels really only ~$145 per wheel? that seems really cheap when similiar wheels are alot more.
thanks guys!
thanks guys!
#60
18x8.75 +20 with 225/40/18 tires you shouldn't need to roll with these specs if you're only dropped on H&R springs.
Yes, Its really inexpensive... its not up to par in quality as forged wheels but I personally have friends using them (track and daily) without problems. It doesn't mean everyone won't have issues with them, i'm just stating from personal experience
#62
are hub centric rings needed with this wheel ? and if so what size?
i would also like an azine opinion on lugs to get. i have an ASM type s and i am going with the chromium black wheel.
i know i want open ended lugs but not sure if i should go with black or the neo chrome.
please help me decide
#64
thanks myron...i want to buy everything i need from nlmotoring.com
now im trying to find a tpms for the new wheels. i found these http://tiresensorwarehouse.com/facto...nsor-1057.html
not sure if they will work and if i will need anything else for them to be installed properly.
im still undecided on the color lugs to get...all opinions will be helpful
#65
if the wheels come with a hubcenter of 73 then you will need a hubcentric ring to fill in from the 73.x to the 64.x of the TLs
not sure how they do sizing.. just know you need it to help with any possible vibrations... i also dont know if you have to have it but from what I read on threads it is best to have it
quasi (01-01-2020)
#66
the specs look just like the XX 527 .. if that is the case use these two links to help
first is fitment depending on your offset and tires
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/fit-discussion-xxr-527-folks-going-agressive-might-fail-hard-814477/
the secon are pictures of folsk with the XXR 527 .. not the same look but you can see how the different sizes and fitment looks
et+20.. has poke.. will.. poke.. and poke real good
as for fender rolling.. I think it comes down to how you are dropped
#67
thanks for the guidance guys...i bought the xxr 530's last night in 18x8.75 +20 all around.
i am super stoked to get them, hopefully i get an email from nlmotoring about when they will be shipping.
i think i have decided to buy my H&R sport springs and have those installed before i decide on tire specs. that way i can have the car the way it will be to get the best look and fit.
#69
i did not speak to nlmotoring about tires but what i gathered so far from people here is that 225/40/18 is a good size tire to run. But most people are lowered 2" or more.
i will not be going that low (only ~1.5" on H&R sport springs) and i also do not want a really stretched tire.
i think i will have the springs installed then decide on tire specs
#71
Im hoping the +20 will because i have a type s and bought +20. ive seen this question in other posts but haven't seen a direct answer yet.
hopefully someone can chime in that already has these or the 527's
#73
found this link about clearing bbk
it looks like +35 wont clear.. but +20 does clear
https://acurazine.com/forums/showthr...hlight=xxr+527
#75
