Xxr 530
#721
The weird thing is I'm not that low, I'm about 1.3-1.5 on tein ss and would like to go a little lower but need to fix this slight rubbing issue. I only hear it on the front left on freeway dips, looks like the tire size and the offset are just enough for rubbing once in a while. Wheels look great though
GeeteeDan (12-05-2012)
The following 2 users liked this post by rockstar143:
asapxjoshy (08-04-2013),
SharksBreath (12-05-2012)
#726
BANNED
rockstar143 (12-05-2012)
#728
that's not much of a stretch, probably similar to a 225 on a 9'er...10MM less equals a 1/2 in less, right (about)...
(nevermind the whale ejaculatez I tried to wax my car with...)
http://www.flickr.com/photos/rockstar143/8106154177/http://www.flickr.com/photos/rockstar143/8106154177/ by http://www.flickr.com/people/rockstar143/, on Flickr
#729
I Like turtles
Thanks, just wanted to see how my current tires would fit on that 18x9.75 in the rear. Debating on going 18x8.75 all around or do the 18x8.75 up front and the 18x9.75 in the rear
SharksBreath (12-06-2012),
The Machine (12-05-2012)
#733
21 Acura RDX Aspec
19x9.75 225/35 rears slammed, tucked, cut and rolled!
SHUT UP about the damn detail and wax/detail needed!!!
#734
21 Acura RDX Aspec
And WA-LA!
#735
Registered Member
Just bought 18x9.5 F and 18.10.5 R +30 all around, and of course will not need spacers. Make sure you do it right the first time so you don't waste your money like I did.
If you do the staggered setup you can do a 215 or 225 tire up front and 225 or 235 tire in the rear. Look at Ebelp's car. He has 215 front and 225 rear and the stretch isn't really bad at all.
#736
I Like turtles
I'm set on the staggered set now and was just wondering since the 235 tires on my aspecs are only a few months old and wanted to swap them over. I still have a small amount of wheel gap in the rear with my current aspecs and my rears are rolled.
My rears
My rears
#737
21 Acura RDX Aspec
Just shot these today to give u a BIRD's eye view...LOL! Get it! BIRD's eye view...Since PREDATORBIRD shot these for me during a Mini Shoot we had today Sorry, thought it was funny
as u can see in the pics. LOTS of work was needed to accomplish this stance. U can see the damage done to the rear tire until it was done right or as much as possible since I am one of the few that still drives with 5 ppl family in his car at this STANCE. Maybe even "THE ONLY ONE"...lol! And my family is the ONLY reason why the rear sits 1/2in higher then what I would like.
check my build thread for the rest of today's shoot
#739
21 Acura RDX Aspec
This maybe true. That is why I was letting you see for yourself and explaining how radical my drop is. As I rolled up to meet PREDATORBIRD/Adam today, His first reaction was, "DAMN! You car is low as hell! and more so in person" True story...I think my lowest point up front maybe only 2in (IF THAT) from the floor. So if u are doing a modest drop, u maybe fine. But I also could have sworn I read someone only on springs and was complaining about rubbing a lot with a meatier tire. Just don't remember the size wheel and tire specs of his 530s.
#741
21 Acura RDX Aspec
Hard to compare APPLES & ORANGES since the stocks have such HI offsets. But surf the 530 thread until you see exactly how u want your car to look, then use that build and stance as a guide. Find out what that person did, did not do and the whole 9... My inspiration was Ebelp (spell that right???) John. I asked questions till I got all my answers...Then pulled the trigger on the exact set up.
JayVee (12-05-2012)
#745
#746
I will post pics tomorrow I am running the 530s on 235 tires with 8.75 all around. I am lowered about 1.5 or so on tein ss, if that. I get slight rubbing on my left front on freeway dips. If I could do it over I might play it safe and get 225 tires. Trying to get fronts rolled and slightly pulled this weekend hopefully that helps. Check out the pics tomorrow to see what you think and then order from there!
I will also take a pic of the slight poke so you know exactly what it is. Little more than I wanted but didn't want to deal with spacers. The poke is for sure more noticeable than you have in your pic of stockies
I did the same center cap switch and all you need is a hair dryer haha
#748
I hear these wheels are coming out in early 2013 in 19's. I have a set of Toyo 245/35/19 tires sitting in the garage for a few years (got a great deal). What nonstaggered size width and offset do you guys recommend for the tires I have? I have tein ss coilovers right now. I don't care for the wheels poking out or stretched tires, but just want a clean simple look. Any insight would be appreciated.
#750
Registered Member
For a clean/simple setup without modification and wanting to utilize your 245 tires, the specs you will have to run are 19x8.75 +35.
#754
for geeteedan: i'm only dropped about 1.3-1.5 on tein ss (minor rubbing issue once that is fixed i'll drop more...so no jokes about my wheel gap ), running 235/40/18 nitto motivo tires, and my wheels are xxr 530 chromium black 8.75 +20 all around. rears are rolled and have a camber kit...fronts might get roll and slight pull this weekend. about 1.5 finger gap all around. if i did it again i would prob go 225 tires
slight driver poke (this is the only tire that rubs on freeway dips)
slight passenger poke
GeeteeDan (01-29-2013)
JayVee (12-07-2012)
#758
I Like turtles
To touch on what has been said... +1 with Jerm, that size tire really ain't saying much as far as aggressiveness. The only thing I see coming out of that size tire in the rear on a 9.75 is PROBLEMS! And that will leave a very bad taste in your mouth about the whole XXR thing when all it was a miscalculation on your end. That tire IMO will be too meaty for the wide of wheel. Trust me! I am STRETCHED and I still have issues and requires some modding for the perfect stance. Go aggressive or stay stock! I also agree with what Jerm when he said those have regretted it for not taking it to the next level. I personally sat on the fence debating what size and what offset. Boy! I am so glad I went the route I did. 18x8.75 w/215-35's and rear 18x9.75 w/225/35's...SPOT MILF~FUNKIN ON!
#760
21 Acura RDX Aspec
