Xxr 521 20"x10.5 + 30 will these fit?
I'm
Thinking on getting these rims after I sell the rims i got. Would they fit my 06 Acura tl 6MT. I know I would have to roll
My fenders prob get spacers and a bunch of other stuff but is it possible? The rear patter is 5x120 but the front is 5x114.3 which is the tl pattern. Why is it different and would the 5x120 pattern fit the rear? Thanks
are you talking about fitting these all around? Then NO if you have to ask, they won't fit. 5x120 is a wrong bolt pattern for a TL, wheels would have to be redrilled or run adapters which will make the rear wheel offset even lower. There would be a lot of work to fit these, and what are you talking about spacers for? those wheels are too wide and too low of an offset to fit normaly, add spacers and you'll need custom wide body to fit these.
I would stay away from these if I were you, you don't seem like you have done enough research into TL fitment to pull this off properly.
I said I thought I need spacers to clear the bbk.. I did not know i would have to re drill to fit the rear. Thanks for the answer.
takin care of Business in
Received 4,732 Likes
OP the TL is 5x114.3 all around....so the rear rims WILL NOT FIT....you will either have to get em redrilled or buy from a place which has all 5x114.3...I dont suggest going the spacer route....too much for nothing....you know what I mean....
