XLR8 ISC Coilovers - Free Shipping!!!
Excelerate Performance is offering free shipping to the cont 48 US!!! We have worked closely with ISC suspension to design coilovers for the Acura TL (2nd, 3rd and 4th gen), TSX (1st and 2nd gen), RSX, and NSX. We have become the exclusive distributor in North America for the Acura models, thus making them XLR8 coilovers manufactured by ISC. So what are ISC coilovers and what are the benefits?
Where do I purchase? The website will give you a free shipping option upon checkout. Here is the link:
http://store.excelerateperformance.c...s/g-65477.aspx
The ISC N1 Coilover is an affordable high performance damper system which offers excellent performance and high quality at a reasonable price. ISC offers suspension solutions for various auto manufacturers including BMW, Ford, Honda, Hyundai, Lexus, Mazda, Mitsubishi, Nissan, Subaru, Toyota, Volkswagen, & more! But we are going to focus only on the Acura lineup.
The N1 coilover can be lowered approximately 3-3.5 inches lower then standard ride height. The spring rates are set up specifically to suit your car and therefore will improve handling and stability dramatically. We can make packages for track/rally/drag and of course street. Our lineup will specifically be designed towards the street/sport customer. However, to offer more flexibility we will offer the option for custom spring rates at no extra charge. This will require extra time but not for this initial stocking order.
ISC N1 Coilover
Features:
32 Levels of Damping Adjustment
- Precise control of valving/damping
- Operates smoothly on all road surfaces
- Expansion/Suppression of shock adjustment
Pillowball Uppermount (RSX) or Aluminum Upper Mounts
- Adjustable camber allows more/less on road track for all conditions (RSX only)
Piston Rod Design
- Strengthened steel piston rods
- Meets race/sport standards
Sports Spring
- Made from high quality SAE9254 steel
- Tested over 500,000 times on compression inspection with less than 5% deformation
- Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free). Spring rates are typically as follows for the Acura models: Street Comfort 10/6 Street/Sport 12/8 Track/Race is 14/10.
Ride Height Adjustable
- Full length height adjustable
- Pre-load adjustable with separate spring locks
- High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
- Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
- Specially anodized surface to prevent internal corrosion and surface rust
- On various models camber can also be adjusted via the bracket as well as the camber tops (RSX only)
Single Cylinder Design
- Larger cylinder and piston design to advance driving stability and dexterity
Free shipping and priced at $895?
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
