XLR8 ISC Coilover Customers - Post up some pics!!!
#161
2014 Jeep SRT
#163
@elkev you might be on to something. The noise does sound like it's coming from the top of the frame. Also the noise is more of a chatter than a clunking. I will have more info after this weekend. Swoosh and I are taking the fronts apart and installing new shafts. Will report back Sunday or Monday.
#165
Moved to the LOU
UPDATE...
Thanks to Anil (SWOOSH) and his major help we were able to complete a few things on my car this weekend. One of them being the front chatter coming from the front suspension. We did a couple of things so I cannot say for sure which cleared up the chattering from the suspension.
First of all we took the entire suspension apart because we installed new shaft/shock bodies. Before hand I also purchased new Bolts and nuts that hold the front lower arm in place. Here is the part description and numbers.
Now that everything is put back together I have no more chatter coming from the front end at all. Maybe it's the new shafts? Maybe it's the new nuts and bolts... I don't know but something made a difference. The preload is set at 174.4 to be exact. We measured with digital calipers. Anil also sprayed the shit out of the threaded shock body with lithium grease to help revent future lockup.
keep in mind if you decide to take apart and rebuild. The process is pretty easy with one caveat. My fronts were maxed out for how low they could go. This caused the shock body and the the sleeve to lock up and seize together. Swoosh had to drive us to a DIY garage to get these apart. We sprayed them with WD-40 and let them sit for about an hour before we went. When we got there we had to put the shock body in a large vice and use a huge pipe wrench to break them loose. Other than that it went very smooth.
Thanks for everyone's help, feedback, patience and everything in between.
Extra thanks to Swoosh for taking the lead on this tear-down and rebuild. I have learned a lot the past 2 times we have worked on my car.
- 90121-SM4-010 BOLT, SHOCK ABSORBER FORK (12X98)
- 90215-SB0-003 NUT, SELF-LOCK (12MM) (CLINCH)(SATO RASHI)
swoosh (01-29-2014)
#166
takin care of Business in
Received 4,732 Likes
aww
Thanks Chris...
I dont think the bolt made a difference....
The main difference was the shorter shaft....the shaft was almost 1.5-1.7 inches shorter on the threaded body side (for more lowering) and was about an inch shorter on the strut side...
This way the spring preloaded very very well...
I am awaiting shipment of the shorter shafts as well...so far ISC has been amazing to work with....
Thanks Chris...
#167
UPDATE...
#168
Moved to the LOU
I didn't have any vibrations. I changed the bolt just because. Thought, who knows, maybe it will help. I also did not have any noise when turning.
The vibration can be caused by the axle of the car when it's really low.
I'm sure you have but when you take it apart just double check your preload and also the top nut.
#169
After all you've been through with the coilovers would you recommend them? or would you recommend going with another brand? I'm currently in the market for coilovers and these were one of my top choices but after seeing this thread it made me want to go with another brand, I'm not new to installing and adjusting suspension components and I have all the proper lubes and tools for the job but I definitely don't want to deal with odd noises while driving
#171
This is what I would recommend to you guys...
ISC N1 has the most adjustability that most coilovers in the market (preload, dampening, height, spring rate as well and comes with top hats)....
Tein has been around supporting the TL and I bet their first attempt was not all aces...this is ISC's first attempt to cater this market....ISC got the top hats wrong and they rectified it....the front struts were making noise for new members and they are working with us to rectify it....this says a lott about the product AND the customer service...
I would recommend ISC. I think its a fantastic product at a great price....The customer service provided by ISC is second to none....they are prompt with emails, they work on fixes and are very friendly at the same time....
UPS just dropped off the shorter front shafts which ISC wants me (and Chris) to test out before they make it a permanent solution for the TL...Not sure if many other vendors provide this level of support....
#172
Moved to the LOU
The Teins were a bit softer, but at the same time didn't stick to thew road as well. With the ISC's you "feel" the road more, which to me is a good thing. Currently my fronts are set at 174.4 for preload and 24 on the dampening, with 32 being the stiffest setting possible.
The shorter shafts have made a big difference. Glad you finally got your's, Anil. I am sure you will have them on the car before the sun goes down. LOL!
If you want more comfot then you should probably go with the Tein's. If you want more adjust-ability and a superior driving experience, go with the ISC's. The ISC's handle the road better and they surely handle high-speed turns much better. And when I say high-speed turns I mean freeway entrances and overpasses. Some of those really long gradual 70mph turns.
#173
being a working day, I think I will have to wait until the weekend LOL
#174
I want to clarify to all the people considering the ISC coilover. I like everything about the coils other than the damn noise I have been experiencing in slow bumps. I recently took the Tl to Baltimore and Atlantic City, it felt good smooth on the highways. The corning speed its supper and feel of the road.
As Anil mention their customer service seems to be on point. I got of the phone with them, about 30 minutes ago and it seems obvious they know there's an issue with the Tl. They seem eager to fix the issue which its a good attribute from a company. I just hope others were as them and that give you that political bs email some vendor (company) give you as soon you say you have an issue.
#175
Still no issues on mine yet after about a month. I'll keep paying close attention for anything I hear.
#176
2014 Jeep SRT
No pics from Chris and Anil's rebuild process? :sadface:
#177
twiggy gotta post them up....
#178
I didnt take any pix since my hands were too dirty from doing ALL THE WORK
#181
lets post pix of the gloves to see who got their hands dirtier
am fuqqing with u bud....most people whose car I work on, they just sit around....you were actively helping...I liked that
twigglius (01-30-2014)
#182
Moved to the LOU
Here is Anil's dirty hand with his Lithium Anal grease he used for maximum lubrication.
New shaft Vs. Old shaft. New shaftr body is 1.5" shorter and the piston is 1" shorter.
Picture of the springs. There is a rust mark and it appears that the top two coils were somehow touching at times.
The rest of the pictures are from Frozen Friday's and the install Anil did of my P&P runners. Not including in this thread since it would be off topic.
#183
Thanks guys for the feedback and help.
I also want to point out that we've installed a number of these coilovers in person and have yet to have any suspension noise. We've also sold hundreds of these and have had only a handful of issues with suspension noise. I'm only saying this so people understand that this isn't an issue across the board.
#184
#185
#186
#188
deja vu
#191
^^^ umm did you read the reviews above?
am not sure how ISC and XLR8 want to handle this situation but since the shorter shafts fit and fit very well, I am sure they will be making it a permanent solution...
with the shorter shafts, you can lower a lot more without messing with the preload...
#192
Of course i read them that's why I'm going with a different brand, this problem is just something i would rather avoid, as I'm sure anyone looking to buy quality suspension is wanting to avoid
#193
ISC is a quality brand...the make and design is awesome....they could have made a height + dampening adjustable coilover and sold without top hats for the same price and still made a lot of coin....
I just feel shorter shafts is something which should have been initially tested....better sooner than later....
and am done here...seems like you have made up your mind...but saying a "coilover has issues" without knowing what it is is just BS to me....
I have no issues with the longer shafts, XLR8 mentioned they have no issues with the longer shafts....its just a few members that have had this issue....could be many many things that could have caused it....
twigglius (02-01-2014)
#194
Don't get me wrong I'm not saying anything negative about the company or their product. It's great that they're working with the community to get the problem fixed, I've been around cars long enough to know that its rare to find that in a company. This is my first TL and all I have to go off of is reviews, I've been reading non stop trying to make the right choice as to avoid headaches in the future, plus I don't want to spend a thousand bucks just to end up with a product that I personally wouldn't be happy with.
#195
Swoosh, how's your suspension running now. I placed a claim with ISC about a month ago and I feel like I'm getting the run around. Every since time i call, they tell me that if my replacement parts were not shipped they would ship the next day. How can this be great customer service? They don't even know what claims order has shipped. It doesn't take 1 month for shipment from New Hampshire to New Jersey.
#196
A J35A8 EG civic is in
#199
yeah their shipment comes in from China...am talking about actually loading up containers and shipping them here....
they they go through custom...
I waited a good 2 odd months for mine...but they did deliver
#200
I just rather them be honest and tell you how long it would take. Not for them to tell you "if it doesn't go out to day it will go out with tomorrow" I will call again today and see whats new about my claim.
