Will those rims and tires fit my TL 06? need help
5th Gear
i plan to get the MRR GT5 rims 19x8.5 offset 35 in front with continental DWS 235/35/19 and 19x9.5 offset 40 in rear with tires 245/30/19
will it fit? rub? suspension still stock now... plan to put tein spring to drop it later on...
please help
please help
5th Gear
so what will be the best size for the tires for the rear rims... for a 19x9.5 rims 245/35/19? 265/30/19? front i'll put 235/35/19 just worry about the rear.
Your Friendly Canadian
Received 1,492 Likes
Don't think it'll rub. What's the bolt pattern? 5x114.3?
As far as tires, I'd go a teensy bit wider, but it all depends on what you want from your tires. I'm sure they'll all fit.
5th Gear
i would like to go with 265/30/19 but scare it ll rub. and i didnt plan to roll fender. yes, bolt pattern is 5x114 offset 35 front rear 40 or 45 better?
nuldabz
09-03-2015 05:49 PM
