will these infiniti hubcentric wheel specers fit?
Hey fitment guru's...
Will these infiniti hubcentric wheel spacers fit my 3G TL? I believe we share the same center bore specs as Infiniti, right? or are they 66.1 and we are 64.1?
Even so if this is so... could these still work?
This is the only high quality solid set I can find in 3mm which is all the wider I need or i'll rub.
http://cgi.ebay.com/ebaymotors/3mm-H...Q5fAccessories
Thx all
Thx all
I see by the pix the spacers have a taper for what I assume is the hub side , does it also have the hubcentric protrusion on the other side that goes in the back of your wheel? Also the center bores are different so the hubcentric doesn't work.
As you said, I guess regardless if it has the hubcentric protrusion on the back side or not, it doesn't really matter since i'd be 2mm off in center bore size anyhow and have some slop.
I might just roll the rear fenders and go for a 8mm set designed for our 64.1 hubcentric center bore.
Hey thanks for saying what I wanted to say, but couldn't find the words for it.
94 DC4 RS LSV/Turbo
it will cause vibration
spacer you require should be 64.1... they have a lip which you then place a hubcentric ring on top of to match your aftermarket wheel... or you can simply install your oem wheel on
nanos
11-12-2015 08:41 PM
sockr1
10-01-2015 01:31 AM
mtl_ilx
09-03-2015 09:48 AM
