Will these fit?
Will these fit?
I'm wondering if these rims will fit with a Tein SS drop of 1.5". Size is 20 X8.5
offset is 25, 34, 45 available.
If not I may just get the 19's.
thanks in advance
thanks in advance
Retired!!! ON TOP!!!
what size tires are you considering??? it's mostly tire size dependent...
Size is 20 X8.5
offset 34, 45 WILL FIT THE FRONT...
Size is 20 X8.5
offset is 25, 34, 45 WILL ALL FIT THE REAR... of course... with the 24mm offset... you'll have to roll your fenders...
I would recommend... the 34mm offset in the Front.... and the 24mm offset in the Rear... the wheels will sit REAL FLUSH to the fenders...
Good Luck
with 235/35/20 or 245/30/20 all around...
Size is 20 X8.5
Size is 20 X8.5
Good Luck
Size is 20 X8.5
Size is 20 X8.5
Good Luck
Size is 20 X8.5
Size is 20 X8.5
Good Luck
real nice... however... the rear wheel will look more tucked into the wheel well... just 'cause of the shape of the car... I think you might have to roll your fenders and cut a portion of the Aspec lip in the rear with the 34mm wheel too...
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
