will this be ok?
Old Aug 19, 2002 | 01:48 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Question will this be ok?
I just got a set of 01' Prelude rims with stock tires. I was thinking of putting them on for winter driving, but the stock size tires are 205/50/16s. Do you guys think that the TL can drive with this size?? Thanks!
Old Aug 19, 2002 | 04:42 PM
BlackShadow's Avatar
O.G.
First of all, is the prelude 4 or 5 lug? If it is 4 then forget about it. If it is a 5 lug then you should be fine since the TL stock is 205/60/16. With the prelude's 50, you will just have less sidewall.
BTW, what happened to you getting the CL-S rims? I thought you said you were going to get it from that guy?!
Old Aug 19, 2002 | 06:02 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
01 lude stock wheels are 5 lug, so you're cool..
Old Aug 20, 2002 | 07:15 PM
numbaonexstunna's Avatar
u can swap ours with lude's and have no problem..so i dont see y it wouldnt work the other way around
Old Aug 20, 2002 | 08:27 PM
SilverUA5's Avatar
Re: will this be ok?
Tires are a bit small. Stock is 205/60/16, you might want to change them to that size or 225/50/16. Post some pics also, I've seen them on Legends, but not on TLs.
