Will a Comptech or Progress RSB help external front dip in turns?
Hi guys,
I have a 04 6MT TL with A-Spec 18" wheels. I'm looking to improve few things on my car: body roll and front end vertical movements in turns. To be more precise I don't like the front end dipping (outter side) on bumbs in tight turn situations.
I'm going to upgrade my rear sway bar soon to a Comptech or Progress in order to limit body roll.
I did read past posts on RSB and A-Spec suspension without finding and awnser to the following questions:
-Do you think the rear sway bar upgrade will also limit the "one side front dip"?
-How does the A-Spec suspension behave in this situation?
-Any of you have used both (Comptech and Progress) RSBs? Which one do you recommend? Keep in mind that I'm in Québec, Canada and I don't want to go too far in terms of "oversteering" potential for snow and icy conditions.
Thanks for your help.
Carl
Carl
Originally Posted by c_potvin
Hi guys,
Carl
Carl
Which one do you prefer.
Carl
The Comptech RSB really helps reducing body roll...its a night and day difference from the stock one. But, you have a 6MT, which already comes with a 19mm sway bar, so going from 19 to 22mm (comptech) wouldn't be much of an upgrade. I'd go for the Progress one.
JJaber06, did you see a noticeable improvement on outter corner dipping (when hitting a bump in a sharp turn) after the RSB upgrade?
Thanks.
Carl
