Will 20 and 15mm spacers fit A-Spec's with 245/40/18 tires?
Old 04-21-2014, 01:45 PM
koolposter's Avatar
Hello All,
I searched and found no definite answer, I think. My car is an 2004 factory A-Spec, so with 18x8.5 OEM A-spec wheels. The tires I have on there now is 245/40/18. Anyone know if 15mm front and 20mm rear spacers will cause any rubbing? With just 2 adults in front or 4 people in car + some cargo in trunk?
Thanks in advance!
Old 04-21-2014, 03:50 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
yes, it will rub a little if you are lowered at all
Old 04-21-2014, 05:41 PM
markp6mttl's Avatar
I am currently running 18x8 +48 wheels with 235/40/18's with 20mm and 25mm spacers and I rubbed a little in the rear. Not bad though. It basically rolled the fender itself and hasn't made a peep since.
I'm going to be installing Tein Street Flex coilovers sometime this week, so I'll see how that affects things.
I think if you were on 235/40's you wouldn't rub much if any. I didn't rub with the stock wheels, 235/45's and the same spacers. It will probably depend on how square the shoulder of the 245's you are running is.
Old 04-22-2014, 06:10 PM
CLtotheTL32's Avatar
Received 9,524 Likes on 6,180 Posts
Fronts will be fine, rears will rub.
james357
02-13-2016 02:37 PM
drone619
01-26-2016 07:09 PM
obert
11-14-2015 09:59 PM
obert
09-03-2015 08:40 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Will 20 and 15mm spacers fit A-Spec's with 245/40/18 tires?
