Will +19mm offset stick out too far?
2012wagon (04-27-2015)
no one can tell you what you should and shouldnt do.
everything depends on your goals and what you want to do with the car.
if you head to 1010TIRES.COM - Wheel Offset Calculator
and input stock specs of 8 inch width and +45 offset then apply your new wheel specs of 8.25 and +19 offset, it will tell you how far the new wheels will extend.
then, you can take a ruler or some measuring tape to see how far the new wheels will stick out.
Then use this newly found information to decide if YOU want to go with the more aggressive offset or stick with the safe option
wheels are not something that you rush into.
it takes time and lots of studying.
"most" people that rush out and buy wheels regret their first big wheel purchase BECAUSE of wrong specs.
make sure that you know how the wheels will look before you pull the trigger.
if you are unsure, more studying is needed.
17x8.25? is this even going on a TL?
justnspace (04-28-2015)
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Joe Avesyan
09-29-2015 03:57 PM
