Wider front tires then rear, 245 front 235 rear
B A N N E D
Hi, do you guys think it would help performance with wider tires in front than the rear?
Since the front tires is responsible for all of the accelrating and more then half of braking, it would make sense to use wider tires to increase contact patch with the ground.
Also, with a wider tires up front with more traction, would that help decrease understeer?
DER NEUE ^
Pontiac website: http://www.pontiac.com/grandprix/specs_viewall.jsp
Accord. to the specs, Grand Prix GXP - 5.3L 5300 V8 SFI, (303 HP [226 kW] @ 5600 rpm, 323 lb-ft [438.0 N-m] @ 4400 rpm) comes with P255/45R18 front, P225/50R18, rear tires. Weight- 3600lb.
Also from the website for GXP model: Wider Front-to-Rear Track Design
GXP’s nearly two-inch wider front-to-rear track is the first of its kind in a production FWD car, matching the contact area to weight distribution for superior control. The increase is due to 18” forged flangeless alloy wheels with an extra inch of width per side, and GXP-specific fenders radiused to accommodate the aggressive P255/45ZR18 performance tires.
Front track width, inches 61.6(Sedan) 61.6(GT) 63.5(GXP)
Rear track width, inches 61.3 (Sedan) 61.3 (GT) 61.7(GXP)
Acura site: http://hondanews.com/CatID3014?mid=2...56021&mime=asc
TL's Track, Front/Rear, in. 62.1/62.0
Please do not do this. I have learned my lesson on tire sizes from having an AWD car. The sidewall of a tire is a certain % of how wide it is (think of it like a 235-45-17, this is not true but to give you an idea the sidewall is 45% if 235). The tl's active handling system will detect that something is wrong and it will not work correctly.
Head a da Family
Originally Posted by chill_dog
The difference between 245 and 235 is only half an inch...you're not going to notice any difference.
- Doc
nuldabz
09-03-2015 05:49 PM
