When do you need a camber kit?
I just put my 19's on, they are 245/35/19 tires.
After F2 Type 1 drop, the alignement shows that I am running -2.1 degrees camber in the rear and -1.5 degrees in the front.
NOT terrible and about a 0.5 degress off from spec for both the front and rear.
Do I need camber kits or will I be fine?
Anyone running similar camber? Can you tell me how your tires are wearing?
Thanks!!!
Thanks!!!
read the sticky above please this question gets asked alot and that sticky was to help and clarify this to people.
u dont need a camber kit really. i am running 19's with a -2.9 camber in the rear and a -1.1 in the front i havent noticed any excessive wear as of yet and i have like 5000 miles on the tires since the drop. if i was any more cambered in the back i would prob get a kit just because i dont like the look of the excessive camber.
your rear tires are free riding with not that much weight on them so they are not going to wear that bad due to camber
Acura TL 04, G37s 19"
i just did an aligment and my car is really drop, about 2.2 inch front and 2.0" rear. The guys who was doing the aligment in a hunter machine told me that it was perfect and i would not required any camber kit. i was so happy to hear that and this is a guys that deals with most aftermark cars around my area.
save your $$ and just rotate
^Agreed. My camber was a bit out of spec which didn't affect the tire wear, but the toe is what killed my rear tires in 5 months.
If you do a search and read into all the replies you'll find that most state that a rotation will keep the uneven wear to a minimum. The tires will wear uneven if the camber is out and I defy anyone to say it won't and let's not hear its only minimal wear on the I/S, it's still wear.
To keep tire wear perfect you'll need a camber kit to get it into spec.
Don't forget that too much rear camber relative to the front will also lead to more understeer at the limit. You want some, but not too much. Around -1.5 degrees in back is a good compromise between handling and wear for me.
My rear tires have accelerated wear with a moderate drop and slightly increased negative camber....even with regular rotation. I have adjustable SmartArm links on order...tires are just too damn expensive to have wearing out that quick.
Former Sponsor
I would at least install the rear camber kit; Ingalls make a kit that adjusts toe and camber. It will save you money by not eating up tires prematurely. I would say it's more cost-effective than replacing tires or paying someone to rotate your tires every oil change.
This is the kit; notice it includes two arms (one for camber and one for toe). You need a qty of 2 to complete the rear of a car.
http://store.excelerateperformance.c...5/i-60220.aspx
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
