Wheel spacers
Originally Posted by ComptechType-S
Anyone useing wheel spacers with their wheels. If so what size are they and did you have to change your wheel studs.
I have 5mm spacers as well. I finally got my wheels on last night. I have a slight vibration from 60-80mph that I am having looked at today. I'm almost positive that its the balance on my wheels. I'll know for sure today.
18x8 GM Falken Torque 5's (38mm offset + 5mm spacer= 43mm offset. Just clears the caliper.)
245/40/18 Nitto 555's
hey.. i have the same problem... vibration from 60-70mph... however, the balancing was done correctly but i was told i need to get "center rings"??? i thought they were talkkng about Spacers...?!?! how do you think i can get rid of this vibration??
Originally Posted by Pure Adrenaline
Usually a small spacer like 5mm won't require changing the wheel studs. You will need spacers that can accommodate 5x114.3.
This is correct. You can always ask your Rim and Tire shop to check and see if you will need spacers with the wheels you are interested in.
I had a smart tire system installed with my rims and tires and they found one of the sensors had broken off on one of my front tires. They checked the balance again on the fronts and thought that the sensor may have been the problem. I still have the vibration, but not as bad. I called Discount this morning and they are going to road force test the tires and then if needed order some hub rings for me. Discount also offered to re-imburse me for the sensor if Vulcantire or smarttire charge me for a replacement.
I must give Discount some props for handling the situation and doing what it takes to make the customer happy.
I got my wheels but took them off. The spacers that i have are not "hub centric" and there was too much wheel vibration. The fact that i will have to change the wheel studs doesnt sit to good with me either. They look great on the car! I am looking into some custom made 5-7mm spacers that are hub and lug centric that are gauranteed to get rid of the vibration. Im just wondering if the spacers will push the wheels out too far.
To you guys with the 5mm spacers.. How close to the fender does your wheel sit?
I took my wheels off and am waiting on some custom built spacers i ordered to get rid of the wheel vibrations. Once i receive the spacers and put everything back on, i will post pics.
jmoney2001
09-11-2015 01:07 PM
mtl_ilx
09-03-2015 10:48 AM
