Wheel Masters. HELP
Old 08-21-2013 | 09:50 PM
chopstix's Avatar
Question Wheel Masters. HELP
Ok need your help. Looking to purchase a set of Work Durandal DD5.2's for my 2007 TL Type S. I'm thinking of this set up:
19X9.5 FRONTS "O" disk either +28 or +30 offset
19X10 REARS "O" disk +25 offset.
Looking to acheive the most FLUSH stance with the Deep look. (Love Polished lips). Not looking for Hella Flush look but know that I will have to stretch tires a bit. 235's all around.
Fenders are rolled front and rear. Dropped on Megan Coilovers with camber kits front and rear.
Question is will "O" disk clear Type S Brembo brakes?
Does my specs make sense to get the FLUSH look? If not...
What specs would you recommend for the Fronts and Rears based on my info?
I've read many posts about this topic, but wanted peeps input on my set up. Any advise helps. Thanks
Old 08-22-2013 | 08:38 PM
chopstix's Avatar
bump
Old 08-22-2013 | 08:42 PM
Italiano's Avatar
Et28 in the front...Rear will be flush...Not sure about the disk and brembos...
If you are lower then 2inches I would run 225/35 front and 235/35 rear tires..
Old 08-22-2013 | 11:53 PM
KJ TL-S's Avatar
9.5 +28 up front is pretty aggressive IMO. According to BforBrian's flush look thread, up front flush is around 19x8.5 +22. I'm at 19x8.5 +20 and I would say I have just a hair of poke. Your setup would poke 5mm more than mine, so you will have a little poke. Rear will be flush too, with just a bit of poke as well.
No idea about disc types and BBKs.
Old 08-23-2013 | 10:55 AM
Italiano's Avatar
I ran a 9.5 et 30 in the front and it looked great,the 2mm difference will still be flush without poking like an rc car...Op..These specs are perfect for what your going for..
Old 09-05-2013 | 09:12 AM
chopstix's Avatar
Thanks Guys.. I think the final set up is going to be 19X9 upfront +25 ( A disk ) and 19X10 +25 (O disk ) in the rears. Debating on tire size if I should run 235's all around or 225's up front and 235's in the rear. Thoughts?
02-25-2020 10:57 AM
KB1_EJ6
11-13-2016 10:51 PM
JByron
01-08-2016 10:49 PM
GhostTL09
09-19-2015 02:57 PM
MyKids&Cars
09-02-2015 01:03 AM
Quick Reply: Wheel Masters. HELP
