Wheel Fitment Help Please...
WEAKSAUCE !!!
Wheel Diameter (Inches): 19"
Wheel Width (Inches): 8.5"
PCD Bolt Pattern: 5X114.3
Offset: 30mm
Hub Bore: 73mm
Will this fit the Acura TL-S / Clear the Brembo's? The shop doesn't know who selling them told me to come by and test it. Sorry i am pretty Newbie when it comes to fitment thanks...
Offset: 30mm
Hub Bore: 73mm
94 DC4 RS LSV/Turbo
as I said in my pm... it will fit but the biggest tire you could run is 225 series
see if they have the offset at +35 to allow you to run 235 or 245
WEAKSAUCE !!!
Thanks Yeah i was hoping to upgrade to some 245 this time around. I got my sway bar on order thanks for the information. Can't wait for the jpipe as well =) Yeah looking for more information if possible...
94 DC4 RS LSV/Turbo
spacers decrease the offset number... the lower the number the more the wheel is pushed out... the higher the number the more the wheel is in the fender...
19x8 +30 with a 235/35-19 tire is even with the fenders
19x8.5 +30 with anything bigger than 225/35-19 will rub, unless you negative camber the wheels and even then there is no guarantee once you lower the car....
JByron
01-08-2016 09:49 PM
nuldabz
09-03-2015 05:49 PM
