Whats the lowest offset we can go ?
just wonder what is the lowest offset we can go ?
Right now i have a set of TE37s 18inch with a +48 offset
im thinking about getting a set of 18x8.5 +22 offset (GT-R Face style) 255/40/18
i also have a Stoptech BBK ... will it fill ?
Columbia Univ. c/o 2004
Originally Posted by 260 HP
Are you sure? I'm running 8.5" with 35 offset and it's already very tight. I imagine 30 mm offset will rub like crazy.
Now if the wheels was only 8-inch wide and not 8.5-inch with 30mm offset, then I think that may fit.
In order to preserve proper suspension geometry (i.e. scrub radius), the lowest (and highest) offset you can go is +45mm - the same as the stock wheel.
Varying my just a few millimeters can result in increased steering kickback, increased torque steer and pulling to one side while braking. Most FWD cars have a zero (or near zero) scrub radius.
The TL's suspension was designed around a +45mm offset. The engineers didn't just pull that number out of a hat - regardless of what any aftermarket wheel manufacturer tells you.
does anyone have the measurements of our fender ? things like center of the hub to the fender (top) and width and stuff .. i want to do a lot of research to try to get these wheels on ..
I should have said, "Most front wheel drive cars have a negative (less than zero) scrub radius..."
The bottom line is that their are adverse ramifications involved with changing wheel offset.
I don't have the measurements, but I bet $100 that 18x8.5 and 22 offset will stick out from the fender lip significantly.
I can send you my Paypal address and I take credit cards, too....![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
