What tires should I run on esr SR01 18x8.5 +30 ?
I’m looking at getting esr SR01 18x8.5 +30 offset but don’t know what tire to run I’m getting tein street flex z ss coil overs for my 07 Acura TL type s but don’t want deal with rubbing but what the flush clean look any ideas on what I should do ?
Cody; with tires; you want to get the rolling diameter as CLOSE as stock as possible. an online tire calculator will help you out with this...input stock tire specs, then input purposed tire specs. the Calculator will spit out dimenions and will tell you if it's too far out of spec.
this is how you get correct tire sizes....
now; if you only care about being SLAMMED and dont care about the rolling diameter; this is where you can stretch a tire so it wont rub.
i like this calculator the best
Tire Size Calculator - Tire and Wheel Plus Sizing
it compares specs...
the one you doesnt compare specs
