What size lugs to get?
This summer I will be putting on my RL calipers and purchasing 350z rotors. Will the rotors affect the lug nut pattern, or will I still be buying M12x1.5? I know that 350z's are m12x1.25. If someone could clarify this, it would be appreciated! Thanks
y r u putting 350Z rotors with RL calipers?? all i know is TLs use 12x1.5 i know 350Z's have the same bolt pattern which is 5x114.3 ... are you using rotors from a Z that have attached studs? im cuonfused now lol
I believe the 350z rotors are a bit thicker. I've never bought rotors before so I had no idea about how they fit since the size of the lug nuts were different. Same pattern, so I'm guessing its still going to be normal TL sized lug nuts as long as the rotors dont have them attached?
Are you running Honda/Acura wheels? If so, you need to get 1.5 studs. Honda/Acura wheels are ball seat types, then you're forced to use the OEM lugs.
If you're running aftermarket wheels, then it doesn't really matter which to get.
neuronbob
23
07-16-2019 10:48 AM
ExcelerateRep
10-14-2015 08:20 AM
