Went for DWS tires...onto alignment....but question
Old 09-28-2013, 05:14 PM
ebernedo86's Avatar
Hey guys I posted something yesterday on which tires to get and decided with the DWS tires. They are currently installing them as we speak and I will get an alignment right after. Now the question is when I go get it aligned..... What instructions do I need to specify to them to make sure it is done correct?
Using the search here I found most people said to set the toe exactly to 0.
Now is this the rear toe? (Or both or front only? I'm not too educated on this topic yet)
I want to make sure I get my wording right so I can get it aligned properly....
Is there also anything else I need to ask them when it comes to alignment?
Thanks in advance
Old 09-28-2013, 07:14 PM
Registered but harmless
Will Y.'s Avatar
Received 1,149 Likes on 775 Posts
Now is this the rear toe? (Or both or front only?...
Both front and rear toe should be 0, or as close as possible to it.
Get the "before and after" alignment specs sheet for your records; you can also post it up if you have any questions.
neuronbob
23
07-16-2019 10:48 AM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
Quick Reply: Went for DWS tires...onto alignment....but question
