Volks RE30s
Volks RE30s
Wheel Make/Model: Volks/RE30
Wheel Size (18x9):
Wheel Offset (+35):
If lowered (amount): 1.75" fronts and 1.5" rears..Planning on doing an even drop with Koni Yellows.
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 04 6 speed with Brembo Brakes
What size tires would I need, and Would this setup fit? would i need to roll my fenders and will these clear brakes and will i need spacers? what camber setting do I need to run.
Im getting these on Tuesday i need help figuring out the things i need to do asap.
Wheel Size (18x9):
Wheel Offset (+35):
My Garage not
1 Post
yea it fits, recommend the stock 18" tire size which is 235/40/18. it might or might not rub, just put them on and see if they do. i wouldn't worry about it until you have them on the car. you don't need to run any camber setting. just drop the car and it'll give it some negative camber which will help the wheels clear the fenders. then get an alignment after you drive around for a few days after you drop the car. you don't need a camber kit.
Wheel Size (18x9):
Wheel Offset (+35):
Wheel Size (18x9):
Wheel Offset (+35):
Im going to go with the lowest perch for the rears and 2nd perch for the fronts. I have the Neuspeed Springs 1.75" fronts and 1.5" rears. Do you guys think it would be an even drop and a nice drop for these wheels? I would need to have my fenders rolled right?
