Varrstoen ES 1.1.1 18x9.5 +12
Looking to pick up a set of Varrstoen ES 1.1.1 18x9.5 +12. just wanted to know if they would clear the brembos on 08 type-s and is there any work that needs to be done for the rims to fit. ex. roll fender, remove mud guards etc.
HE>i
roll/pull fenders, add camber, and i think they do clear brembos.
are you lowered any? in the end it will be worth it to put the work in to make them fit. search member name (nivekov)? has similar rim setup 18x9.5 +15 i believe
here you go ....https://acurazine.com/forums/showthr...714121&page=26
alex2192 (05-16-2012)
Thats the exact same specs I'm running in my 04... You don't need a camber kit. Natural camber is all you need. And I did MINOR rolling and pulling for that specs to fit and I'm tucking part tire as well.. And yea you'll need coilovers.. I'm running 16k in the rear and 14k springs in the front for stiffness and I daily it with no problems at all...
alex2192 (05-17-2012)
Yes they are used, i found someone selling them in my area. As for coilovers, im debating teins or i really like my k-sports when i had my rsx. so im going to do some more readingand decide.
nuldabz
09-03-2015 05:49 PM
digimidi
03-01-2008 05:25 PM
