VarrsToen 2.2.2 Help
Chapter Leader (San Antonio)
First you will need to read this, https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/everything-you-need-know-about-wheels-tires-837398/. Then you will need to find fire, water, a key, and a map. Then you will be set free.
The following 2 users liked this post by TheChamp531:
The Machine (07-27-2012),
Undying Dreams (07-27-2012)
Welcome to the forums.
Moved to Tires & Wheels.
Undying Dreams (07-28-2012)
First you will need to read this, https://acurazine.com/forums/showthread.php?t=837398. Then you will need to find fire, water, a key, and a map. Then you will be set free.
I have the 2.2.1's. the 2.2.2's will fit easily on a stock TL. What offset are you looking to get? Heres my 2.2.1's in 18x9.5 +22 all around. My fenders are rolled and pulled though because im lowered.
![](http://i1104.photobucket.com/albums/h324/twkoch/DSC_0043.jpg)
you dont need a camber kit. Just get an alignment and make sure your toe is at zero. don't have a camber kit and im lowered almost 3 inches
+30ish would be flush. You only have to worry about your brakes getting in the way if you have brembos
nuldabz
09-03-2015 05:49 PM
XxXboboXxX
08-04-2012 07:15 PM
