Type S 18 inch wheels-stock suspension
Old 04-27-2016, 11:48 AM
  #41
Andrew
VisualEchos's Avatar
Originally Posted by E39
Wait 265 40s wouldnt cause any rubbing issues?!
265/35. And remember, rubbing is caused by a whole lot of things...
- Every make/model tire is different
- Drop
- Roll
- Sidewall
- Weight in the back
- Camber
That's why it's so hard to give people exact answers; it's a multi-faceted issue.
justnspace (04-27-2016)
Old 04-27-2016, 07:20 PM
  #42
Received 16,260 Likes on 11,971 Posts
Very well said ^
Old 04-28-2016, 06:02 AM
  #43
E39
E39's Avatar
Ron jon
Guys would ron jon legacys in 18x8 +32 clear brembos?
Old 05-03-2016, 11:43 AM
  #44
Former Sponsor
VMRWheels's Avatar
Hey Guys!
We had an 08 TL-S in for test fit and confirmed the following will clear the Type S Brembos:
V710FF in 19x8.5 ET35 or 19x9.5 ET33 or more aggressive ( 19" only model )
V803 in 19x8.5 ET35 or 19x9.5 ET35 or more aggressive ( 19" only model )
V804 in 19x8.5 ET35 or 19x9.5 ET35 or more aggressive ( 19" only model )
V810 in 18/19x8.5 ET35 or 18/19x9.5 ET35 or more aggressive
V701 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
V705 in 19x8.5 ET35 ( Limited sizes for 5x114.3 application )
V710 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
Or 20x9 ET35
V718 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
V721 in 19x8.5 ET35 ( 19" only wheel )
The following 2 users liked this post by VMRWheels:
sockr1 (09-08-2018), viking00 (05-03-2016)
Old 05-03-2016, 12:13 PM
  #45
sockr1's Avatar
Received 1,158 Likes on 909 Posts
^^ tracy you should make this a separate thread because it would be VERY useful to anyone in the future. i wish i had this about 6 months ago i would have gone with vmr for sure!! if you make a separate thread i would just suggest adding weights for some of those sizes
it should maybe be made a sticky! thanks for the info, some of the best looking wheels out there.
VMRWheels (05-03-2016)
Old 05-03-2016, 01:47 PM
  #46
Former Sponsor
VMRWheels's Avatar
Duly noted!
I'll probably update our general thread in the TL subsection with this same post and throw in some weights too for all to see
Thanks for the kind words!
Old 05-03-2016, 03:20 PM
  #47
KCCO
MarcoNorthPolo's Avatar
I'm lowered a little bit, but it does poke like 2 or 3mm.
a quick glance, it looks flush.
Hawt.
Old 05-03-2016, 04:59 PM
  #48
E39
E39's Avatar
Originally Posted by VMRWheels
Duly noted!
Would VMR wheels require hub rings for 3g tls?
Old 05-03-2016, 05:47 PM
  #49
Andrew
All aftermarket wheels should require hub rings, they're made that way on purpose, that way you can make 1 wheel (with a hub hole that's too big for everything) and fit it to every car with just a ring.
Old 05-03-2016, 06:11 PM
  #50
E39
E39's Avatar
Ohh i see. Any negatives in running hub rings?
Old 05-03-2016, 06:40 PM
  #51
Andrew
None whatsoever. Some guys are complete idiots and don't run them if there is a small gap, but you don't want to be like them, trust me.
Old 05-05-2016, 01:33 PM
  #52
Former Sponsor
VMRWheels's Avatar
When we manufacture our wheels, we actually bring them in as blanks so that our machining shop will custom machine PCD anything from 5x112-5x120 and hub bore anything from 57.1-74.1. The end result? No hub rings needed! Perfect bolt on fitment!
This is true for about 99% of wheels out there for sure!
With our custom machined wheels, they are machined to be a 100% direct fit including hub bore. No need for rings!
Not necessarily. Good quality hub rings will do the job well. Some Audi/VW owners have reported back negative feedback but these are indicative of running ball seat lug bolts and not lug nuts, which our Acuras thankfully do not have.
Old 05-12-2016, 11:33 PM
  #53
iWhine
H23Accord's Avatar
+1
The VMRs fit perfect to the point that even my tech was impressed with how perfect they fit. No hub rings required. I am still running stock lug nuts as well. Fantastic wheels and they aren't really heavy either. I believe my 19s are maybe 24-25lbs each. OP is looking at 18s so obviously they would be lighter depending on wheel choice.
VMRWheels (05-19-2016)
Old 06-19-2018, 05:20 PM
  #54
E39
E39's Avatar
Does anyone know if Tsw Nurburgrings 18x9 +32 or enkei raijin 18x8.5 +35 have major poke and give the car a 4x4 look on stock type s suspension?
Old 06-19-2018, 06:21 PM
  #55
sockr1's Avatar
you will have a little bit of poke with 18x9+30 (i currently have that wheel but i'm lowered). 18x8.5 +35 will be no poke.
also look into vmr 710 18.8 +35, that will be my next wheel if i switch from nurburgring
Old 06-19-2018, 06:35 PM
  #56
E39
E39's Avatar
Nice. The vmr's or Enkei raijin in 18/8.5 +35 shouldn't give the car a 4x4 look right? Can I do 255 40 tire or should I stick with 245 40? What about a 45 series tire would that rub? I'm stock height.
Old 06-20-2018, 12:29 AM
  #57
E39
E39's Avatar
Would 18x8.5 rub on 255 40 tires stock suspension?
Old 06-20-2018, 10:17 AM
  #58
sockr1's Avatar
i think you'll be fine with a 255 tire at stock height, but that's just my opinion. i know you for sure would be ok with 245/40
Old 10-19-2020, 04:17 PM
  #59
E39
E39's Avatar
17 inch aftermarket options
Anyone know of any good aftermarket 17inch options for a stock type S? Something strong enough to hold up to nyc roads. I wouldn’t mind going with aftermarket wheelership waffles but I have concerns about them holding up to nyc roads. My oem waffles have taken a beating from nyc roads and most of them have bends to some extent or another.
ryanfett
04-19-2016 08:04 AM
John Landry
03-24-2016 10:39 AM
E39
02-29-2016 02:55 PM
The Machine
02-26-2016 08:21 PM
TRIUMPHT
02-25-2016 05:22 PM
Quick Reply: Type S 18 inch wheels-stock suspension
