Type S 18 inch wheels-stock suspension
Old 04-24-2016, 04:14 PM
E39
E39's Avatar
What aftermarket wheels in 18 inch on stock suspension look best on a type s? Which options would give the least of the 4x4 look?
Old 04-24-2016, 04:52 PM
Andrew
VisualEchos's Avatar
What looks best is going to be up to you. If you're looking to close that wheel gap, choose a tire that's about 26" instead of 25.5", which is the stock OD.
18 x 9.5 +40 w/255/40/18, no drop.
Summer.
by Andrew Thompson, on Flickr
Old 04-24-2016, 06:01 PM
E39
E39's Avatar
What would be some options? I cant seem to find any aftermarket wheels that clear brembos without having major poke on stock suspension giving it tge 4x4 look.
Old 04-24-2016, 07:39 PM
Andrew
I'm not sure, I don't have Brembo's, but I'm certain your answer is in the wheel/tire/fitment thread at the top of this forum.
Old 04-24-2016, 08:00 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Tsw Nurburgrings 18x9 +32 and enkei raijin 18x8.5 +35 are the two wheels I narrowed my search to when I wanted a more conservative fitment (flush...my first set was more aggressive) and still cleared brembos. It's very very hard to find wheels that clear brembos and don't give too much poke or need camber. Took me a few months of research when I picked my two sets of aftermarket wheels. Good luck, have patience, and do lots of searching like mentioned above.
VisualEchos (04-25-2016)
Old 04-25-2016, 02:49 AM
E39
E39's Avatar
Thanks for the input fellas. If i get the tsw or enkei what tire size should I go with? 245 40? Can i go any wider and taller maybe a 45 series on stock type s suspension? Are tsw good quality wheels and do they hold up well on potholes?
Old 04-25-2016, 03:04 AM
E39
E39's Avatar
Any other options? Especially concave style?
Old 04-25-2016, 03:17 AM
E39
E39's Avatar
17 inch options
I also would consider 17 inch options. Want to eliminate as much fender gap as possible.
Old 04-25-2016, 09:20 AM
sockr1's Avatar
the tsw wheels are very good quality, i currently have them.
you can probably go with a larger side profile or 245 and be fine
you won't be able to have a concave wheel without lowering (there will be major poke if you leave it at stock height). it's just the way it is with having brembos and not wanting to lower it.
Old 04-26-2016, 10:25 AM
E39
E39's Avatar
If I went with either tsw nurburgring or enkei raijin would a 245 40 or a 255 40 tire option work at stock height and still be within the 3% recommended spec?
Old 04-26-2016, 10:27 AM
E39
E39's Avatar
Summer.
Sweet looking ride! What rims are those TSW? Would those rims work on the type s?
Old 04-26-2016, 10:29 AM
E39
E39's Avatar
I currently have waffles on on 245 45 17s. Would going to a 18 inch rim with a 245 40 or 255 40 series tire make the fender gap more obvious compared to 17s with 245 45?
Old 04-26-2016, 10:38 AM
Received 16,260 Likes on 11,971 Posts
with tires, you want to have the same rolling diameter as STOCK.
so, there wouldnt be a perceived difference in gap, because rolling diameter will be the same or as close as possible.
Look at VE's car for reference. he changed both wheels and tires but kept the tire at the same rolling diameter and it looks PRETTY close to stock wheel gap
TacoBello (04-26-2016)
Old 04-26-2016, 10:40 AM
^use a tire calculator to show you what I mean.....
Old 04-26-2016, 10:43 AM
both of the proposed 18 inch tires are very close in diameter to your current 17 inch tire.
The following 3 users liked this post by justnspace:
EvilVirus (04-27-2016), soital (06-01-2017), TacoBello (04-26-2016)
Old 04-26-2016, 10:46 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
As Spaceman pointed out, you don't want to change the overall outer diameter of the tire, otherwise your speedometer will be reading wrong. If you want to close the fender gap, you have to lower your car. No two ways about it.
justnspace (04-26-2016)
Old 04-26-2016, 11:05 AM
sockr1's Avatar
Vmr wheels. Those wheels will not work on a type s
Old 04-27-2016, 02:30 AM
E39
E39's Avatar
Thanks for the input guys. I spoke to a local wheels shop and they said they have STR 901 and STR 903 wheels for my car. Specs are 18x9 offset 20. Have any of you guys ever heard of STR racing wheels? Dont want to buy cheap wheels at the risk of wheel failure. The guy at the shop obviously says they are good wheels and that they hold up well. I looked em up a bit and they seem to be relatively light weight and are made using a technique called flow forging, whatever that may mean but I doubt they are true forged wheels. Thoughts? Pictures of said wheels 901 on top 903 bottom -
Old 04-27-2016, 06:13 AM
flow-forging is a mixture of cast and forging, it provides the benefit of forging and also keeps the cost down of true forged wheels.
but how its made is non-important as OEM wheels are casted and they are pretty stout.
those wheels that you've picked out are replica styled wheels, as in they were copied by STR to look like their authentic counter parts. nothing is wrong with this!
if you like them, grab a set!
Old 04-27-2016, 08:21 AM
sockr1's Avatar
Those will poke big time if you don't lower. They look nice though! What weight are they?
justnspace (04-27-2016)
Old 04-27-2016, 08:58 AM
yes, I poke with 18x9.5 +22
Old 04-27-2016, 09:02 AM
I'm lowered a little bit, but it does poke like 2 or 3mm.
a quick glance, it looks flush.
Old 04-27-2016, 09:21 AM
sockr1's Avatar
^^that setup looks great! i don't consider that poke really. OP is saying he wants to run wheels on a stock suspension. when i ran my xxrs 18x8.75 +20 on stock suspension for a few days it looked so so bad haha (mucho poke)
Old 04-27-2016, 09:26 AM
it takes some getting used to tho. everytime i look at my car in the garage, i'm like wtf, the wheels poke out!
agreed tho, with natural camber dude is going to poke with no drop.
Old 04-27-2016, 09:51 AM
E39
E39's Avatar
They are supposedly 17.5 lbs! The guy at the shop says there wouldn't be any poke that they'd be flush but yea we know thats impossible. Im more worried about the quality of the wheels in that they don't fail if pushed to the limit. I've heard stories of replica wheels just not holding up and failing catastrophically which obviously can be a dangerous situation. Plus I live in a city full of potholes. The guy is willing to sell me a set of these wheels for $650. Good looking wheels at 17.5 lbs for $650? Sounds too good to be true no?
Old 04-27-2016, 09:59 AM
Andrew
Miro 112 actually, with a custom Hyper Silver finish by Detroit Wheel and Tire. I don't think they will work on a Type S, specs are 18 x 9.5 +40.
Old 04-27-2016, 10:03 AM
Andrew
You would hella-poke without lowering. I poked 5mm in front and was flush in the rear with 18 x 9.5 +40, so you would poke 23mm in front, and 18mm in rear.
The following 2 users liked this post by VisualEchos:
justnspace (04-27-2016), sockr1 (04-27-2016)
Old 04-27-2016, 10:07 AM
well, i have been raising up my front end lately. Its so stressful to drive, being low (and im not even that low!)
its been poking alittle bit more as i raise it, will get an alignment with natural camber soon
Old 04-27-2016, 10:16 AM
sockr1's Avatar
i was the same way with my xxrs...i was low and was always worried about hitting on dips and scraping and everything else until i finally got to a point where i was like i can't even enjoy the "speed" of my car and drive aggressive when i want.
so i ran it by my wife (of course played the "it will be more comfortable" card), and sold my xxrs and got a flush setup with my tsw, got 235 tires instead of 225, and raised my car up a little bit.
i drive so much more relaxed now and don't worry about hitting anything, meaning i can push the car whenever i want and not get a gut wrenching feeling while driving.
lowered cars look great, but took me a while to find the balance of looking great and functionality.
Old 04-27-2016, 10:18 AM
Andrew
That's one of the reasons I didn't slam my car. The only time my car scrapes is when I come out of my own damn driveway, and just the plastic air-thingie in the front.
Getting there.
Old 04-27-2016, 10:19 AM
seriously! VE knows something we dont! lol
no, butt seriously, I'll probably be back at aspec height if I keep raising every weekend
sockr1 (04-27-2016)
Old 04-27-2016, 10:21 AM
VE cant be the only one picture whoring;
Old 04-27-2016, 10:27 AM
sockr1's Avatar
haha yea VE! my turn
The following 2 users liked this post by sockr1:
Backpack zo (07-16-2020), justnspace (04-27-2016)
Old 04-27-2016, 10:37 AM
OoO I like the teal grean caliper.
I want to change my color!
Old 04-27-2016, 10:42 AM
Andrew
Bubbe, I probably know a lot you don't.
Old 04-27-2016, 10:43 AM
Classic!
Andrew
Anyway, 265 FTW!
Tail Happy.
Old 04-27-2016, 10:47 AM
^im doing that next.
so, when I bought the wheels, they came with 245's, which give the tires a slight stretch. I'm like you and like my tires beefy!
in a few months, i'll grab a 265 set!
VisualEchos (04-27-2016)
Old 04-27-2016, 10:49 AM
^VE; i know you have a summer tire thread, butt i'll drop this nugget here
The following 2 users liked this post by justnspace:
sockr1 (04-27-2016), VisualEchos (04-27-2016)
Old 04-27-2016, 11:29 AM
E39
E39's Avatar
Wait 265 40s wouldnt cause any rubbing issues?!
Quick Reply: Type S 18 inch wheels-stock suspension
