Type S 18 inch wheels-stock suspension
#41
265/35. And remember, rubbing is caused by a whole lot of things...
- Every make/model tire is different
- Drop
- Roll
- Sidewall
- Weight in the back
- Camber
That's why it's so hard to give people exact answers; it's a multi-faceted issue.
- Drop
- Roll
- Sidewall
- Camber
justnspace (04-27-2016)
#44
Former Sponsor
Hey Guys!
We had an 08 TL-S in for test fit and confirmed the following will clear the Type S Brembos:
V710FF in 19x8.5 ET35 or 19x9.5 ET33 or more aggressive ( 19" only model )
V803 in 19x8.5 ET35 or 19x9.5 ET35 or more aggressive ( 19" only model )
V804 in 19x8.5 ET35 or 19x9.5 ET35 or more aggressive ( 19" only model )
V810 in 18/19x8.5 ET35 or 18/19x9.5 ET35 or more aggressive
V701 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
V705 in 19x8.5 ET35 ( Limited sizes for 5x114.3 application )
V710 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
Or 20x9 ET35
V718 in 18/19x8.5 ET35 or 18/19x9.5 ET33 or more aggressive
V721 in 19x8.5 ET35 ( 19" only wheel )
Or 20x9 ET35
#45
^^ tracy you should make this a separate thread because it would be VERY useful to anyone in the future. i wish i had this about 6 months ago i would have gone with vmr for sure!! if you make a separate thread i would just suggest adding weights for some of those sizes
it should maybe be made a sticky! thanks for the info, some of the best looking wheels out there.
VMRWheels (05-03-2016)
#46
Former Sponsor
Duly noted!
I'll probably update our general thread in the TL subsection with this same post and throw in some weights too for all to see
Thanks for the kind words!
#48
#49
All aftermarket wheels should require hub rings, they're made that way on purpose, that way you can make 1 wheel (with a hub hole that's too big for everything) and fit it to every car with just a ring.
#50
#51
#52
Former Sponsor
When we manufacture our wheels, we actually bring them in as blanks so that our machining shop will custom machine PCD anything from 5x112-5x120 and hub bore anything from 57.1-74.1. The end result? No hub rings needed! Perfect bolt on fitment!
This is true for about 99% of wheels out there for sure!
With our custom machined wheels, they are machined to be a 100% direct fit including hub bore. No need for rings!
Not necessarily. Good quality hub rings will do the job well. Some Audi/VW owners have reported back negative feedback but these are indicative of running ball seat lug bolts and not lug nuts, which our Acuras thankfully do not have.
#53
iWhine
The VMRs fit perfect to the point that even my tech was impressed with how perfect they fit. No hub rings required. I am still running stock lug nuts as well. Fantastic wheels and they aren't really heavy either. I believe my 19s are maybe 24-25lbs each. OP is looking at 18s so obviously they would be lighter depending on wheel choice.
VMRWheels (05-19-2016)
#55
also look into vmr 710 18.8 +35, that will be my next wheel if i switch from nurburgring
#56
#59
17 inch aftermarket options
Anyone know of any good aftermarket 17inch options for a stock type S? Something strong enough to hold up to nyc roads. I wouldn’t mind going with aftermarket wheelership waffles but I have concerns about them holding up to nyc roads. My oem waffles have taken a beating from nyc roads and most of them have bends to some extent or another.
TRIUMPHT
02-25-2016 05:22 PM
