TSW Nurburgring or another wheel setup ? Need wheel gurus input.
I need some help and opinions from the wheels guru here.
I was looking at the TSW Nurburgring 18" in matte gunmetal for my car which you can see here :
https://acurazine.com/forums/3g-tl-photograph-gallery-96/my-take-asm-2008-tl-s-spring-here-update-4-19-13-a-864573/
As much as I like the color and spoke design of that specific wheel :
http://www.tsw.com/alloy_wheels_nurburgring.php
I'm realising I do like a wheel with a lip and not necessarely a crazy 2.5" lip on it. I was wondering if you guys had an idea of a wheel model that would be similar to it and in the same kind of price range that would fit my Type S ?
If it gived you a better idea I'll be getting coilovers and have my roof painted gloss black this spring so I'd like a set of wheels that will help set the whole package apart.
Thanks in advance for the help guys.
Received 6,470 Likes
Brakoo, I've always liked the Nurburgrings. They remind me a lot of the OEM Type S wheels.
18's or 19's will do you good.
Avant Garde M310
Desert Life Sucks!!
I was looking at the TSW Cadwell.
Thanks - I really like the rims. I'm going to run black lugs this summer and am going to modify the center caps to be black and white.
@sauceja: I haven't had any fitment issues clearing the brembos and no rubbing on the fenders. I'm not sure how the other TSW's are for back spacing.
To anyone interested in matte finish rims, Adam's Quick Sealant does a great job at retaining the color of the rims and provides a nice satin slippery feel.
sauceja (01-27-2013)
Really like those rims. Wife just bent my rims yet again. So bought the BE Breyton gts - av from tire rack for 200 each in 19's and love the new look. They ran out of gun metal so did hyper silver
They're 18x8 +35
Jon
Thanks! Nope...nothing special was done at all. What tire are you using? The actual width seems to vary between models/brands. I got mine from Discounttiredirect.com: http://www.discounttiredirect.com/di...w=8&vid=012180
They're 18x8 +35
Jon
They're 18x8 +35
Jon
Rich
Hey thanks for your help Jon! I'm using the same size wheel as the factory including offset and width. The tire I'm using is a Continental Extreme Contact DWS 245/45WR17... The tire is 10mm wider than the 235/45WR17. I purchased 5mm wheel spacers in hopes of getting a little more clearance so they don't rub against my strut tower... Will 5mm be enough? I would like to go with 15/20 but won't those add too much mass weight to the wheel therefore decreasing performance and fuel economy further?
Rich
Rich
BANNED
JDMJDK77 (04-09-2013)
I'm thinking small and 4x4! lol ...I had them on the stock type s suspension for about 12 hours before I had my a-spec suspension on. It looked a bit weird ..I have a pic somewhere. The center caps were ugly as sin too (polished).
Received 3,824 Likes
I would definitely lower the car some if you're putting aftermarket wheels on...
I've been playing with the center caps a bit and decided to switch it up..threw black lugs in for fun. The black and white center cap should match the brembos. I figured this was appropriate here since we're talking about Nurburgring's. :-)
The Type S suspension is a bit lower than the base suspension from the factory. I would assume the wheel gap in the front would be a bit larger on the base suspension.
Bringing this back up. I found a set of these 18x9 +32 tires are 245/40 need to know if the fit!
If someone can tell me these clear brembos for the ones who have the Type S TL's that would be great I know jon2000 yours are 18x8 +35 offset please let me know!
Hey! I just took off my winters this evening and put the Nurburgrings back on. I clear the Brembos and rear fenders jwith my setup but I would guess that you'd have to roll the rear fenders with the fitment you mentioned. I'm considering a 5mm spacer in the rear to try to get it closer to the fender but even that may rub when loaded down. I'll have to look into this. The suspension + rear swaybar + wheel/tire combo feels perfect! Smooth/firm/planted.
Yeah,
I am at stock height on mine right now. Tires are a little bit bigger. I am not on Aspec suspension though!. I think they would have no problem. I am going to test fit them on Saturday morning at my buddies shop. At your stock height did you have a problem? I am not sure if the 1in to become the 9 in wide is really going to make a huge difference. Then again I have no idea. Thanks Jon for the quick reply!
Agreed! Here's my car before I had the a-spec body kit and suspension on, the rear quarter windows tinted properly and the center caps were original. Pretty much 2 weeks after I got the car ...
i say you go xxr 530 +20 offset, i just got them put on with 225/40/18 tires and they look outright nasty. They are alot more concave than the TSW's but thats just my 2 cents
Hey there, resurrection time!
Felt like sharing...
I'm about to do the same setup (18x8 +35 ; 245/40/18 V12's; Square Setup), but I'm on a stock AT Type-S suspension.
I'll post pics with the stock AT Type-S suspension and then after with the drop. Probably will be up by the end of the month.
