TPMS works with which set of wheels?
WDP TL'S FTW
Hello, I just got me a 06 Acura TL and I was looking to get some Work's Varianza. A friend of mine said they won't work with the TPMS unless I drill a hole in the wheels. Can anyone tell me if this is accurate and which wheels would work with it?
Originally Posted by limited
You can either drill a hole in the back or use bands to mount them. You can't stick them in like the OEM wheels.
OMGWTF4THGENTL
Originally Posted by ray64105
Has anyone gone the route of drilling a hole for the TPMS sensor? I always see banding as the solution. Is drilling typically avoided because it can weaken the wheel or just to keep any warranty intact?
From your other thread... You have to use bands becasue 2 piece wheels have a 4 inch L shaped valve stem that starts in the CENTER of the barrel of the wheel. Single piece wheels have the valve stem hole int eh outer FACE of the wheel.
You cannot mount the sensors properly in the center of wheel.
