TPMS won't fit into my 18" rims :(
I just purchased a set of 18" wheels and a set of brand new OEM TPMS from Acura.
The hole on the rim is too small for the valve stem thread to go thru.... so i cannot put the top nut on to secure the TPMS in place.
what can i do with the TPMS now?? Please help
I have car ADD
iForged makes TPMS adapter brackets.... did your new wheels come with their own valve stems? these adapters just hook over them... I am using them on my 2pc wheels
be SURE to use loc-tite on them, as they have the chance of falling off and bouncing around in the wheel until they break
Or, you could widen the hole....
94 DC4 RS LSV/Turbo
Iforged adapters are iffy... I'd widen the hole and call it a day, wouldn't hurt there at all, get a big enough drill bit in and out couple times should do the trick
LIST/RAMEN/WING MAHSTA 짱
If it's a 1-piece rim, the TPMS should fit no problem. Maybe you have some generic rims?
As mentioned above, the iForged TPMS Adapters work well for 2-piece rims.
Using a drill to widen the valve stem hole could "screw", as it only takes 1-2 spins to make the hole too wide. What'll you do then?
run without the TPMS. if you check your tire daily there is no reason to be dependent on them.
i ran w/o TPMS for almost a year with no problems until i needed to swap tires, then i mounted the factory TPMS on my current wheels.
Originally Posted by ALSCAPS
IF anyone cares we sell the iforged valve for $8 ea.
516-742-6823
516-742-6823
look how to secure the TPMS sensor on ronjonwheels.com, you can buy the strip they used from home depot or lowes usually.
Originally Posted by amk6453
but if u run without TPMS, i thought theres warning light will come out on your dash board?
Type- (S)low
Originally Posted by Jesstzn
There is .. its about the size of a grain of rice and not noticable. You also get an audible which only comes on once a driving session and you just cancel it.
I widen the hole just test drill on piece of metal 1st no biggie.
Originally Posted by Paul_2007S
That would annoy da heck out of me. you gotta push "ok" in the nav , then if you don't put you seat belt on , now cancelling the tpms light.... imo thats way way too much everytime when I get in the car.
I never have the seat belt problem .. old car racer .. and not invincible .. so I use it.
09-15-2015 06:44 PM
