Toyo T1R
Toyo T1R
I have Toyo T1R tires size 235/35/19, on the tire it says the MAX load is 615kg or 1356 lbs. Does this mean that the tires can hold up to that weight. How much does an 05 AT TL weight.
thanks.
thanks.
That's right, THTL, the MAX load on each tire (1,356lbs) in your case, is the max load per tire. So the MAX load for your car is 5,424lbs (1,356x4). Keep in mind that this is the MAX load, and you shouldn't try to drive with this much weight on your car all the time.
Btw, the curb weight for your car should be around 3,500lbs, so you have almost 2,000lbs (1 ton) you can carry in your car and still be safe.
