Too low, too stiff and tires too big = want to go back to stock
Registered User
I picked up a 05 6spd a couple weeks ago, and I'm pretty sure it's been lowered by the previous owner. Here;s couple pics of the car.
To me, the car is too low and too stiff for my daily commute on not so nice pavement.
What's worse is the previous owner put on 245/45/18 tires, which is 1.3 inches larger than stock all around. And when I take a right corner that slops up hill, it definitely rub.
I'm not sure what kind of suspension is on the car, I need time to take off the wheel and check. It may have a rear sway bar too, because the rear end definitely feels more stiff and does not roll when taking corners at high speeds.
I'm definitely thinking about going back to stock because I need a comfortable ride.
Registered User
hmm...I uploaded them to picasaweb and linked it here
http://lh4.ggpht.com/_zIOAYyV1LxU/SS...78483_9231.jpg
http://lh4.ggpht.com/_zIOAYyV1LxU/SS...78482_8672.jpg
Maybe picasaweb doesn't allow linking?
Otherwise the pics are in this album
picasaweb.google.com/NBP056SPD/NewTL#
Being an Acha Bacha in
Yeah definitely looks dropped and looks like it was dropped on non ASPEC springs. Just double check to see if it was lowered on coilovers or any suspension that has dampening control, if so, you can adjust the ride softness a little and it might be to your liking. You can also try to raise it a bit, only if its a coilover suspension.
If its just springs, then yeah, you gotta revert back to OEM wich shouldnt cost you much, just get a used set on the forum for like 50 bux and swap it out. Remember with lowered vehicle you get much better handling so you will lose that.
Registered User
Hopefully I'll have time to take off the wheels and look at it this weekend. Hopefully the aftermarket suspension the previous owner used are good stuff and adjustable.
This is the first lowered car I've had. Is the ride quality suppose to be that much worse than stock?
I remember all I ever wanted in my Legend was to drop it, but that was my younger days. Now my older bones needs a cushier ride.
Registered User
Ok took pictures of the springs and shocks. Looks like it's got stock shocks with aftermarket springs? I couldn't find any markings on the springs. The shocks says HONDA on it. Anyone know what kind of springs these are?
AZ Community Team
Received 7,771 Likes
Shocks are indeed stock. Here are the part numbers for the '05, 6MT rear shocks:
52610-SEP-A13 SHOCK ABSORBER ASSY., RR.
My H&R Sports are Dark Blue (TL-S) and so are mmade22's ('05 MT)
Doesn't Tokiko or Tanabe have an "OE" spring thats red/orange?
AZ Community Team
Maybe these: http://www.tanabe-usa.com/springs/sp...ions.asp?id=1# Tanabe DF210
Drop ~ 1.5" and the main page shows them as a similar color.
Registered User
But my tires are too big, so it rubs, I'm sure a 245/40/18 will work just fine.
Hopefully when I take these out and replacement with stock ones, I'll see some kind of markings.
My Garage not
1 Post
245/40/18 will work fine, the stock 18" tires are 235/40/18 so you can do that too. how many miles does the car have on it? i would think about replacing the entire shock units. if the original owner had been running that drop for a long time the stock shocks are probably near the end of their life. you can get stock shocks for cheap in the BM or buy a-spec which would be a huge improvement in handling if you don't want to be dropped anymore.
Oderint dum metuant.
Can't see the pics, but from what I've read...
Swift has red springs, drops a little over an inch. Pick up a set of stock shocks/springs and put them on (can probably get a set cheap in the Black Market). Once you do, figure out which springs you have and sell them in the BM.
245/45/18? Those need to go immediately. With an 18" inch wheel, you should be running a 40 series tire, unless your wheel is extremely wide (x9, x9.5). I'm assuming it's not, so I'd go with 235's, but 245's are good, too.
Registered User
The tires are almost new, so I'm planning to run them down before getting a different size.
Registered User
Also my wife ride with me in the car a lot, and eventually we're going to have children. I want her to be comfortable and the kids too.
Like I said above, back in my bachelor days. All I ever wanted was to drop my Legend, but didn't have the money. Now I can afford it, and have it, I don't want it...oh well, can't win
AZ Community Team
Registered User
Thanks for all the comments and help. I really appreciate it.
I have to say, I do like the way the drop looks on my car with this suspension setup. The handling is awesome too, it was really different than the 08 base TL loaner I drove last week (quite a bit of body roll and floaty)
I just bought stock suspensions, hopefully they'll be here in a week or so.
IIDXholic
10-08-2015 07:53 AM
