TL wheels on a TLS...
I'm thinking ahead to Winter and snow tires for my TLS. It seems like I can get a set of "base" wheels cheaper and more easily.
So my question is, will wheels from a base TL clear the Brembos on a TLS?
Full of water...
i am almost 100% sure that is a yes. the tl-s has no bigger brakes than the MT base TL, which has the stock rims, so you should be all good
i dont have the BBK, but i was thinking about getting some base stocks to put some winter tires on. my all seasons dont cut it in 6+ inches of snow
Full of water...
but what you should really do is slap some winters on your tl-s rims, and then buy some 18" or 19" and put some high performance summers or all seasons on them. then you ride would look really hot
Full of water...
Originally Posted by Broke9
Thanks for the quick replies. I didn't realize that the MT had Brembos as well.
I guess I know where to come for TL wheel info!
they also have a limited slip differential, and a thicker rear sway bar...
and this isnt just the place for wheel info, its the best place for all TL info
btw, welcome to the forum
2007 TL TYPE S ASM
You have to use a 3mm spacer to make sure they clear. I switched out the TLS wheels for the stock wheels when I purchased the TLS because I couldn't stand the black wheels (personal preference). When mounting the stock TL wheels it was so close to the brembo brakes, that a very small spacer was needed. I went online and found a 3mm spacer that I am still using until I purchase the A-spec wheels.
JByron
01-08-2016 09:49 PM
