tires on a 19 axis hiro
06 TL tricks are for kids
ok I got a 06 TL with nav.. i got some 19 axis hiro with 235/35ZR19 tires on them... the car hasnt been dropped.. is it possible to put a little bigger tire on them? i'm not a tire specilist but how about some 245 something or 235/45??
Whats the width? If you running 8.5 then you will nave no problems.
I got Axis Milano 19x8.5 with a +35 offset running 245/35/19 RE960AS. Car is dropped about an inch, and I have a finger gap in the rear and 1.5 fingers in the front.
So, you will be able to run 45 series, but why? If you EVER plan on dropping, then you will have problems.
Again what are the exact specs on Hiros?
__________________
Kansas City/Missouri Meet!!!
__________________
the off set is +35.. i do a lot of traveling from KCK to wichita ks.. about 165 miles.. and just driving on the high way alot. the car isnt drop yet but i'm thinking of doing about a 1 inch drop. Also what tires do you recommend on for tire life? I baby the car around hardly ever get on it, It stays under 4k rpm..
Ok, I'm assuming you running the 19x8.5 setup with 35 offset. If you plan on dropping then just stick with 35 series. I would bump it up to 245/35/19.
In terms of what brand of tire. Question lies within do you have your stock wheels/tires still? If you do, I would keep them to use as winter wheels, then from my personal preference and doing homework for about a month before I bought tires, I would go with the Bridgestone Potenza RE960AS.
__________________
__________________
so doing a 1 inch drop in the future i would be ok with running Bridgestone Potenza RE960AS 245/35/19?
i still have the factory wheels and the tires are perfect, so no issue with using them for snowy weather..
Bridgestone Potenza RE960AS 245/35/19 i just googled them and they are about 250 each.. any place in KCK or KCMO you can recommend that would have them a bit cheeper
know what the life on the tires are? approx?
http://www.tirerack.com/tires/tires....e1=yes&place=5
has reviews of the tires. And your right they 243 a pop. Damn I payed that much for them
plus another 100 or so for install, and they fucked up the paint on the rims too. AHHHH.... Whatever you do, take it to a shop that actually does work with aftermarket wheels no maw n pop shop...
CostcoFanAUS
09-18-2015 06:05 AM
