Tire size question (general question)
Hi, I have a question in general regarding tires...For example, let's say that a car currently had:
Bridgestone EL-42's and the size was 215-55-17
If the customer decided to switch to a:
Falken 512 with a size of 225-50-17
then would that be a problem at all? Unfortunately Falken doesn't make the tire for 215-55-17, so in switching to the wider tires, would anything go wrong with the car? sensor problem? thanks in advance for your opinions...
TL = Tranny Lubrication
Tire size 215-55-17, changed to 225-50-17 you will have a difference in your speedo of 1.7%, meaning if your speedo says 60 mph you are actually travelling 59 mph.....
Registered VTEC junkie
Wider tires will not necessarily harm the ride. Try to maintain the stock diameter. Stock tire size 235/45/17/ is 25.3" tall. If you go wider, yes the aspect ratio will have to decrease to maintain stock diameter. Which means less sidewall.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
