Tire sidewall question here
Hey guys id like to know if a low profile high performance tire has a stronger sidewall than a low profile touring tire?
I wanna know which tire can protect my wheels better from potholes
thank you
thank you
'06 750Li Sapphire/Creme
You probably laready realize this but the accurate answer is... It depends.... Specifically, it depends on the manufacture and even the model number. The General UHP's are solid performance tires but I have heard (from others on here) that their sidewall is softer than other tires. Does that mean that they are a soft as XYZ's "touring" tire? Hmmm, maybe but in order to determine that, I would need to know what brand of touring tire you are comparing this too. Even then, there are no studies that comapre sidewall firmness (that I am aware of) so your really back at square one. In "general", the sidewal on MOST performance tires will be stiffer than the sidewall on MOST touring tires. Your question is not "quantifiable" so the real answer is... who really knows...nobody.
Registered but harmless
Received 1,106 Likes
I dunno either...
If potholes are a primary concern, go with the touring tires so that impact forces are distributed through the tire rather than transmitted to the wheels and suspension. You'll probably also get a softer ride and less tire noise in a touring tire, with less dry traction at the limit, than the ultra-hi-po tires.
thank you
thank you
re
what do falken tires have that they guarantee rim protection? extra padding in the sidewall to prevent rims from denting on potholes contacts?
