Tire Rotation and MID
After reading the manual for my '06 TL w/o Navigation, it sounds like the MID will notify me when it is time to rotate the tires just as it tells me when to change the oil. I called my local Acura dealership, and the service manager confirmed that the MID will remind me to rotate the tires.
However, I now have 10,800 miles on my TL, and I have never seen a service waring regarding rotation of the tires. I noticed that the manual says to rotate the tires every 7,500 miles. Am I incorrect about the MID service warning? Shoulld I rotate the tires anyway?
I drive about 85% on the highway and have the stock Bridgestone tires. They do not appear to be wearing at all so far. Thanks
The mid should say B1 service due soon which is oil change and tire rotation. Like said above you should rotate your tires every oil change if possible, this will give your tires a little bit longer life and even wear.
Well here is what i found:
Main item A- is replace engine oil
Main item B- is replace engine oil and oil filter, rotate tire and inspection of vehicle
Sub item 1- is rotate tires check psi
Sub item 2- is replace engine air and pollen filters and check belts
Sub item 3- is replace transmission fluid
Sub item 4- is replace spark plugs, replace timing belt, inspect valve clearance
