Tire question
Tire question
I was just seeing what you guys would recommend running for tires on a set of 18" aspec rims????I'm looking for a good set nothing to crazy in price if possible
I wouldn't go any narrower than 225/40/18. People have run 255s on stock wheels which are the same width so you could go 255/40/18 if you really wanted to.
I have 235/40/18 on my 8.5" wide A-Specs with no issues.
Stay Out Of the Left Lane
Received 1,245 Likes
Are you looking for an all season tire or are your A-Specs going to be dedicated to Summer use? Are your A-Specs 8.0 or 8.5 width? I have the 8.5" width and also have my Type S rims for Winter use. On my A-Specs, I am running 255/40 R18 with no issues.
From Mass??I live right outside of boston myself..I was probably going to grab 245/45 18's
Stick with a 40 sidewall. 45 will throw off your speedometer and look terrible.
It will give you an idea of what the differing sizes will do to your speedo as CL mentions and also give you scaled images of the tires if you select it on the right side under options.
