tire psi
tire psi
Hey guys,
It's probably been posted before, I looked couldn't really find anything.
What psi are you running in your stock tires?
I've pumped mine up to 35psi, last car I found that one or two psi really make a big difference in ride/handling quality.
Dave
Dave
Gratis dictum
I generally carry 10% more air in the fronts than in the rears. I have 33 psi in back and 36 psi in front. The car seems to handle and ride much better with this ratio.
PS This should probably be in the tires/wheels forum.
Registered but harmless
Received 1,149 Likes
I run 34lbs all around, as opposed to Acura recommendation of 32lbs all around.
However, Repecat is correct if you decide you want to cut down understeer or are involved in autocrossing-- lower rear tire pressure will make the TL handle more neutrally.
Originally Posted by dmarcus48
Hey guys,
Dave
Dave
i run the same pressures in my winter tires/wheels.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
