tire pressure question
what is the ideal tire pressure to keep on tires for maximum longevity??? max tire pressure; 5psi below max; 10psi below max, 15psi below max???
Well, just tires in general, if you look at the stocks on the TL, max press. is 44psi and you mentioned 32psi. The tires I had a question about have a max press. of 51psi's. On aftermarket tires, what would be ideal for a max. press. 51psi tire???
