tire pressure during cold nights
so ive been noticing on cold nights, my tires pressure is dropping so im getting the tire pressure warning next morning, but after a little driving pressure goes back up. my question is should i be adding more air so it wont loose much pressure during cold nights? or is it fine? lol just trying to find out for future refrence and just being cautious lol
runnin a little boost
I think the tire warning comes on at below 30 psi, you should be at 34-36 psi cold and tire pressure shouldn't go down to below 30 psi. I used to run 40 psi on my stock rims and tires to get better mileage.
Mine triggers below 28psi. Recommended pressures are when cold. Add air to your tires.
Received 6,470 Likes
This just happened to me tonight (for the first time). I'll be adding air tomorrow.
Off roading in his
What would be the tire pressure recommendation for Bridgestone 235/35R19?
I tried checking on the Bridgestone website but was not successful. The tire says, see owner's manual. My future father in law (a mechanic) suggested that the low profile tires may need more pressure than stock. Right now I have the fronts as 37 psi cold and the rears at 35 psi cold, but the ride seems a bit stiff, so any suggestions?
Registered but harmless
Received 1,107 Likes
Unfortunately, the stiffer, lower sidewalls will mean a stiffer ride.
rockyboy
08-04-2024 10:35 AM
NBP_BALLER
09-23-2015 08:18 PM
